B6100 Head Gasked replacement
   / B6100 Head Gasked replacement #1
swierczt
Durham, CT
Kubota B6100
I am replacing the head gasket on my B6100. I found a small leak on the intake manifold side. I got the head off (a previous owner had snapped the head off of one of the bolts on so it took a little work to get that one out!) Any suggestions as to how to remove the carbon from the head before I measure it on a surface plate to see if it is warped? I have not removed the valves...is it necessary to remove them? Anything else I should be aware of? Thanks!
2018 Allmand Light tower (A49461)
2018 Allmand Light...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
19008 (A48082)
19008 (A48082)
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
