B3300 Shuts Off When I go Forward/Reverse
   / B3300 Shuts Off When I go Forward/Reverse #11
I thought there was a sensor behind the rear tire for the forward/reverse pedal too? I have two switches on my seat, one for the operator weight and then another that gets pushed if you tip the seat up which I have no idea its purpose..? If I take the two wires that go to the switch and just connect them, will that basically by-pass the switch and keep it engaged all the time?
I believe the one when the seat is tipped up allows the tractor to run while you use the PTO to run a chipper for example.
   / B3300 Shuts Off When I go Forward/Reverse #12
And this switch caused your B3300 to stop running when you would move forward?
On my BX the switch was anchored with two screws into a Tinnerman type clip. It kept coming loose so I fashioned a piece of flat bar with two tapped holes for hardened hex key NF bolts. End of problem. Maybe look for a similar situation.
Ron
Ron
And was your switch located in the same place as in that video?
   / B3300 Shuts Off When I go Forward/Reverse #14
The BX is arranged different. the switch is behind the RR Tire. The clip is back behind other stuff, almost impossible to get to. I'll see if I can resurrect my old post on that subject.
Ron
I just wanted to update this in case another person came looking to this thread. The seat switch did turn out to be the issue. I ordered a new one for $6 and the issue has not reappeared after 10 hours on the machine.
   / B3300 Shuts Off When I go Forward/Reverse #17
Thanks for reporting back. That will likely help others
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
