B2910 bevel gear case leak
   / B2910 bevel gear case leak #1
dlabrie
Campton, NH
Kubota B2910
I have a tiny leak between the bevel gear case and front gear case on my B2910. I looked at the shop manual and it looks like there is an O-ring between the 2 parts which are held together by 4 bolts. It looks like an easy repair. Is it simply a matter of removing the 4 bolts, sliding off the bevel gear case, replacing the o-ring, and putting it back together? Gear oil is cheap and the leak is small. Can I forget about it and periodically check the oil level?
   / B2910 bevel gear case leak #2
From looking at the diagrams in the IPL, it appears as if it will just come off. Though, there are a lot of components, so be conscious is something just falls out.
Or it could go the other way, where it won't come off.
Only way to find out is by taking those 4 bolts off.
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2010 KENWORTH T660 TANDEM AXLE MID ROOF SLEEPER (A58017)
2010 KENWORTH T660...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2013 John Deere 245G LC (A55272)
2013 John Deere...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
