B2650 HSDC KUBOTA Starting & creeping problem
   / B2650 HSDC KUBOTA Starting & creeping problem #1
thewczuk
Kubota B2650
I'm sure this question has been answered a million times. I have a 2018 KUBOTA B2650HSDC CAB TRACTOR that I purchased new and after starting it and for any reason shut it off it will not start. This does not happen all the time and the only way I can get it to start is having someone cross the starter while I'm turning the key on. Sometimes if I play with the HST pedal it will start or wait maybe 10 to 15 minutes, then it will start. I've had this problem most of the summer and it would not be a problem except that I suffered a stroke 3 years ago and can't walk without a walker. I have over 2,000 ft of driveway to plow this winter and am afraid that if it stops for any reason I'll be stuck in the cold.
   / B2650 HSDC KUBOTA Starting & creeping problem #3
Does sound like your neutral safety switch is not working every time it is at rest. You need to test the switch
As for it shutting off while it is running. Do not shut it off while plowing. It will keep running unless you run out of fuel.
If you cannot test the circuit them you really need a dealer to fix this issue.
   / B2650 HSDC KUBOTA Starting & creeping problem #4
Just have to throw it out-is the HST travel pedal pivot well greased?
Don't forget the OPC-Operator Presence Control system.
Good Luck!
2025 KJ K1230 UNUSED (10) Wire Mesh Netting Rolls (A50860)
2025 KJ K1230...
(2) Tractor Tires and Rims with Spacer (A50860)
(2) Tractor Tires...
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
UNUSED 20PCS 2in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 2in...
