B2320 - how to take off dash plastic cowling
   / B2320 - how to take off dash plastic cowling #1
HCamp
MX5100, B2320
Yesterday I mowed with the B2320 for several hours, turned off the engine for an hour or so, and when I returned to start the tractor up again nothing, no clicks or any other sound or lights on the dash when I turn the key, and no headlights/turn signals when I try the light switch. Battery is fine - I can crank the engine by shorting the starter solenoid terminals, and cranking speed sounds normal, but it won't start, I assume probably because of a stop solenoid on the fuel pump. All the fuses in the fuse box by the starter are good.
Next I was going to check the key switch which is mounted on the big plastic cowling. I have a puller for the steering wheel, but I only see one attaching screw on the center top of the cowling and don't see how it comes off. Would appreciate info from anyone who's done this!
Thanks much,
Howard
   / B2320 - how to take off dash plastic cowling #2
I don't know if ours are set up the same, but my 2650 has 2 bolts down at the bottom of the cowling that need to be taken out.
Joe
I'll check it out. Thanks much!
Howard
2018 John Deere 2025R Tractor - 647 Hours (A56435)
2018 John Deere...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2010 Freightliner M2 106 T/A Altec D2050A BR Digger Derrick Truck (A55973)
2010 Freightliner...
1322 (A58374)
1322 (A58374)
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
FIMCO 60 GALLON SKID MOUNT SPRAYER (A52708)
FIMCO 60 GALLON...
