B21 HST strainer
   / B21 HST strainer #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Seems like the HST strainer elbow tube is quite stiff. Assuming its rubber. I'm concerned about cracking it at some point. So close to the end of this task I can taste it. Only some of that is brake cleaner overspray. I'm going out with a electric heat gun now to try and soften it up. Other ideas?
   / B21 HST strainer #3
What task? Brake cleaner overspray, in relation to what/when?
   / B21 HST strainer
An attempt at a joke. Used a lot of brake cleaner where the pressure washer did not hit. Around the filter housing, and such.
   / B21 HST strainer
Can you post a pic of the strainer elbow?
It looks like a radiator hose 90 degree bend about 1 1/4 inch diameter. No matter, I did get it to come out a bit and it did not want to flex enough to pull the strainer out. The other end was up very difficult to get at and seemed to have two hose clips on it. I pulled it out as far as I could, realized it was clean as could be and called it good.
   / B21 HST strainer
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
American Sanders Super 7R Electric Wood Floor Edger (A49461)
American Sanders...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
