B21 block heater install
   / B21 block heater install #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Today was the day I was going to install a block heater on my B21. Thought I had a hex large enough to fit the plug that has to come out. I was wrong, or lost it.
Anyone know a cheap source of large hex wrenches, etc?
   / B21 block heater install #2
Amazon. Also use tape. I tried to used the pipe dope and couldn't get it to seal.
Sent from my iPhone using TractorByNet
   / B21 block heater install #3
Harbor Freight has large Allen wrench sockets. You will need a breaker bar and some heat to get the factory plug out. It was hard to get mine out of my B2400 block. I used a piece of hex rod and a 3 foot pipe wrench and preheated the plug with a torch.
I got the set from HF. I'm changing the thermostat while I have it drained. Anyone know the proper torque for the 12 mm bolts?
So, filled the cooling system then went to get a fan belt. Got back and there was a little pool of green liquid in the heater housing. Cleaned it up thinking I may have spilled some. In less than ten minutes the puddle was back. Keeps growing too. Wonderful.
RIMS AND TIRES (A50854)
RIMS AND TIRES...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A51039)
2023 New Holland...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
1994 Mack CH613 Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2015 JEEP Compass (A50324)
2015 JEEP Compass...
