murphy1244
Super Star Member
- Joined
- Nov 25, 2011
- Messages
- 19,510
- Location
- Ohio
- Tractor
- Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
There is just a small problem with that in that with the hoe attached, you cant get to the couplings, you have to unhook the back hoe, drive forward a foot or more to get to the hoses so I couldn't just stick one inline and see what was happening. The tractor has no other hydraulic outlets on it. I suppose I could unhook the hoe, then put the gauge in between the lines (you unhook from the hoe and loop the supply to the backhoe back into the return. I don't think I would get much pressure showing in the loop as it would just be circulating to an open end so I wouldn't think it would show me any pressure above the resistance. I watched a video of someone checking the flow by doing the same thing, except they had a needle valve to gradually shut down the flow till it dead headed to check the max pressure before the relief valve opened. Flow seems to be based on no load conditions, as the pressure builds flow decreased till 0 at max pressure and dead head. That is what I was concerned with was that the relief valve was set too low. NOW it would be nice to have a flow meter and verify the flow.
Anyone know where to get one of those?
Attach the tee inline with the FEL.
