Auxiliary Hydraulics Modification for 422/425
   / Auxiliary Hydraulics Modification for 422/425 #12
hmm, looks like a great idea, but it would cost about $450 to change out the couplers on the attachments that I have now. I think I will take a pass on this modification.
Am I the only one, who every time I am out in the garden or the woods working, think "if only I had that extra PT attachment, I would be able to do this in a heartbeat". So I start pondering dropping $1500 for an attachment that I will use once a year for a couple of hours...
   / Auxiliary Hydraulics Modification for 422/425 #13
bbabineau said:
... if they would allow me to change from my minihoe to 4in1 without waiting an hour for the connectors to cool ...
I usually wear gloves when I operate the tractor and have no problems with my connectors. One time I didn't have gloves on and disconnected the mower.... YIKES!!!! I burned my fingers. :eek: Since then, I went back to gloves.
   / Auxiliary Hydraulics Modification for 422/425 #14
I do the same thing...even dream up projects that are not on my "to do list" which will require an additional attachment. A local xmas tree farmer is contemplating a PT purchase and immediatly more attachments for me ran thru my mind to cut down on shipping. Probem is I'll have to build another storage shed for the additional attachments.....yet another project!
   / Auxiliary Hydraulics Modification for 422/425 #15
Bob,
Way to go! Thanks for putting it all together in one easy to read post. Geez, it's almost one stop shopping. You guys are the best!
   / Auxiliary Hydraulics Modification for 422/425 #17
bbabineau said:
JJ
Question on flat face couplers - I can't seem to find them in 1/4 inch with the change under pressure option. Do you know if they exist or are they only for the larger applications?
Bob
Try this site, They are not cheap. A smart friend once told me to always use a coupler one size up when using quick disconnect. The reason is that the orifice for the fluid is smaller than the ID of the line. Therefore, if you are going to use quick disconnects on a 1/4 line, use 3/8 quick disconnects and you should maintain the flow. If you look at the coupler, you will see what I am talking about.
http://www.discounthydraulichose.com/?type=GoogleAdWordsSearch
   / Auxiliary Hydraulics Modification for 422/425 #18
In the vein of keeping it all in one place, I compiled this list from surpluscenter.com. I think these are the right parts. Plus it includes 1 male quick connect, which you might need if you want to change to male/female on a mini hoe or 4n1. I'm not sure if the male QC below is the correct one, it's kind of a guess.
Bob, would you mind verifying if this looks kinda right? I'm not holding you to it or anything ;)
1/4 NPTF SWIVEL TEE (ALL SWIVELS)
Item# 9-1603-4-4-4 $4.50 2 @ $9.00
1/4" CARBON STEEL BALL VALVE BBVN20040001 359858
Item# 9-5540-4 $27.95 1 @ $27.95
1/4 NPTM to 1/4 NPTF 90 ELBOW
Item# 9-5502-4-4 $1.75 2 @ $3.50
1/4 NPT HEX NIPPLE
Item# 9-5404-4-4 $.75 4 @ $3.00
1/4" NPT QUICK COUPLER TIP S41-2
Item# 9-5924 $3.95 1 @ $3.95
   / Auxiliary Hydraulics Modification for 422/425 #19
Oops, In my last post, I said to get a male QC, but I think you'd need a female. Anyway, this list will supply 1 complete coupler...
Item# 9-1603-4-4-4 $4.50 - 2 @ $9.00
Item# 9-5540-4 $27.95 - 1 @ $27.95
Item# 9-5502-4-4 $1.75 - 2 @ $3.50
1/4 NPT HEX NIPPLE
Item# 9-5404-4-4 $.75 - 4 @ $3.00
1/4" QUICK COUPLER S10-2
Item# 9-1626 $13.49 - 1 @ 13.49
   / Auxiliary Hydraulics Modification for 422/425 #20
Tim,
I'm a bit confused here. Why would you need a Quick Coupler at all (either male or female), if you are plumbing it the way that BobRip did? He permanently connected the hoses to the QA circuit, unless I'm mistaken, and reused the Quick Connects that are originally on the tractor for use with the attachments requiring the Aux PTO.
Am I missing something here?
2015 GMC 3500 HD 4x4 Crew Cab Pickup truck (A55973)
2015 GMC 3500 HD...
2010 Chevrolet Express Shuttle Bus (A55852)
2010 Chevrolet...
UNUSED PABREAK GB232 - 84" HYD GRAPPLE BUCKET (A57193)
UNUSED PABREAK...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
(4) Tractor Spacers (A56469)
(4) Tractor...
