Auger with "hiccups" while spinning...
   / Auger with "hiccups" while spinning...
When you connect the 2 halves of the PTO shaft are the U-joints on both ends in phase. That is when one X is horizontal the other must match it. If not, they will be out of phase and traveling at slightly different rotation speeds.
oh that's interesting, so both ujoint should aligned. That might be what happened, because half of the driveshaft fell down when moving it and then I just inserted one inside the other and that might have cause the problem, that they are unaligned. Tomorrow I'm gonna check that up, thanks!
So I aligned the ujoints and it worked like a charm! Thank you all for the recommendations and ideas, it helped!
UNUSED IRMC HIGH END ELECTRIC MASSAGE CHAIR (A57193)
UNUSED IRMC HIGH...
2024 John Deere 35 P Excavator (A53485)
2024 John Deere 35...
Giyi 48" Mini Excavator Root Rake (A56469)
Giyi 48" Mini...
2011 Ford Ranger Ext. Cab Pickup Truck (A55852)
2011 Ford Ranger...
UNUSED IRMC HIGH...
UNUSED FUTURE 20' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 20'...
