Auger with "hiccups" while spinning...
   / Auger with "hiccups" while spinning...
When you connect the 2 halves of the PTO shaft are the U-joints on both ends in phase. That is when one X is horizontal the other must match it. If not, they will be out of phase and traveling at slightly different rotation speeds.
oh that's interesting, so both ujoint should aligned. That might be what happened, because half of the driveshaft fell down when moving it and then I just inserted one inside the other and that might have cause the problem, that they are unaligned. Tomorrow I'm gonna check that up, thanks!
So I aligned the ujoints and it worked like a charm! Thank you all for the recommendations and ideas, it helped!
2008 Ford Crown Victoria Sedan (A55853)
2008 Ford Crown...
UNUSED FUTURE HYD WOOD DRILL (A57192)
UNUSED FUTURE HYD...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
BUSH HOG 74" ROTARY TILLER (A57192)
BUSH HOG 74"...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
TITAN 185-6' FLAIL MOWER (A57192)
TITAN 185-6' FLAIL...
