Attaching chain to draw bar
   / Attaching chain to draw bar #21
Eric_Phillips said:
How do you guys attach a chain to either the belly draw bar or a draw bar on the three point? I was wanting a shackle that the chain would slip through. The problem I keep running into is if the opening is big enough to fit over the draw bar the pin is too big to fit in the hole.
Like this
Clevis available at Tractor Supply.
Using my 1964 MF-135 diesel to pull that old almond stump. Cut most of the lateral roots before yanking it.
UNUSED JCT HYD BACKHOE DIGGER ARM (A57193)
UNUSED JCT HYD...
TANK MANIFOLD (A55745)
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
2014 TAKEUCHI TB228 EXCAVATOR (A52707)
2014 TAKEUCHI...
2013 Kenworth T440 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55852)
2013 Kenworth T440...
