Attaching Brush Hog on 3pt what kind of top link do you use ?
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #1
kingrace78
Bronze Member
Prescott, Ks & Lee's Summit, Mo
AC D14, LS XR4046H
Always before on my old AC I used a chain for the top link with a brush hog, this allowed the mower to flex on uneven ground. I just bought a new LS tractor and I am wondering what most people do brush hogging on uneven ground. I would think a solid toplink would bend.
John
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #2
My brush mower and finish mower, the link that the 3 point top link connects to pivots. This allows both to follow the ground while limiting travel some and allowing a level lift.
I have also used mowers in the past without attaching the top link.
I know others who have used a chain.
The stuff I mow though is a few fields I have mowed for years just to keep the brush down. Don't know how much a deck could jump if hitting unknown objects or small tree's.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #3
I use a solid top link but the way my land lays there is no problem. If I had rough ground I would use a chain or better yet use a trailer hitch type. I used a trailer hitch type for years and like them best.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #4
Another solid top link user. My RC also has the pivoting connection point, which works well enough. I'm not mowing a golf course with my RC, so the occasional scalp is no big deal.
Joe
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #5
Mine has a solid top link, BUT the Bush Hog has chain going from the top link down to the mower
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #6
I use a hydraulic top link which works great for me, even better would have been if I had thought to get it with float, live and learn.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #7
Solid top link (factory jackscrew) but the Rotary Cutter has a pivoting top coupler that allows for quite a bit of upward movement of the cutter.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #8
My cutter has a float clevis at the top link. This allows deck to follow ground contour for most conditions but limits it to about 45 degree so it can't rotate/flip up beyond safe operating angle.
   / Attaching Brush Hog on 3pt what kind of top link do you use ? #9
I think the best is the swivel joint at the top on the bush hog. These can be retro-fitted to just about any mower and they give enough movement for even the deepest ditches without binding but still gives a solid link back to the tractor.
Thanks everyone, I will look for a swivel joint. That sounds like the best option.
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2018 John Deere TX Gator (A50123)
2018 John Deere TX...
Kioti DK 35, 4WD, Quick Attach Loader with Bucket  (A52384)
Kioti DK 35, 4WD...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
