At Home In The Woods
   / At Home In The Woods
Tonight I read EEPete's reply and decided to run the well tank wire myself and put in breakers for the H&A guy myself tomorrow after work so the waterline can be installed Friday. So we called the well guy this evening to let him know the schedule. It turns out his helper is going out of town Friday. The well guy has a bad back and cannot install the piping. So we can't get the waterline work done until Monday which means I can't backfill the trench this weekend. If it weren't for the rocks in our dirt, backfilling the trench would take no time at all with the FEL. However, I want to hand fill the first part of over the pipes to prevent rocks up against the pipe and that takes time.
My wife looked at the electrician's bill for our electrical rough-in. He has already charged us for roughing in the wire to the water pressure tank. Of course now he's claiming that's work that the well guy does, not him. I'm sure he's forgotten that he billed us for that. Obviously the electrician is not in my good graces right now.
On a positive note, we got the meter for the house installed today by the utility company. We now have power to the house. The picture shows 2 utility meters, one on the temp pole that powers the camper and one on the pedestal that powers the house.
attachment.php
We have 44 days to get our occupancy permit or the power to the house will get disconnected. If the power to the house gets disconnected, we will lose power to the well which would mean our camper would have no water.
Aren`t ou using the well right now, for the trailer? I appreciate your frustration....Tony
Tony,
Yes and that won't change. We currently have a temporary pressure tank at the well house. When the waterline is run to the house, the permanent pressure tank will be installed in the house and the temp tank at the well will be removed. There will be a wire run in the waterline trench from the pressure tank in the house to the well. A pressure switch in the pressure tank will turn the pump on whenever the pressure in the waterlines gets too low.
Obed
Obed, That detail on the 2x looks great...Our trim carpenter did the same thing on our 2X6 pressure treated rails for our decks and porches...it really makes a difference as opposed to just a plain board...You might want to have him do the same to your deck and porch rails on the edges of the boards..
Bob, great suggestion. Thanks.
Cabinets
The cabinet maker owes us a proposal for building our cabinets with the changes that he and my wife have worked out. He was supposed to get us the bid this past Friday. Today my wife asked him when he would be finished installing our cabinets. He said he couldn't start working on them until after Thanksgiving.
So my wife went to see our second choice cabinet maker this afternoon. This cabinet maker can have our cabinets installed in 3 weeks. They have 8 guys in a shop building cabinets. We are going to get a new up-to-date bid from them.
   / At Home In The Woods #2,135
Man, it never ends does it? I like Pete's description...
This is one of the main reasons I want to do as much myself as possible. I won't fight (with who? myself...?? ) about who's job it is to do some detail, and I will be satisfied that it is done correctly (or I will fix it until it is right...). My biggest problem will be time... There's always a critical constraint in any project. It's just nice to be able to pick the one you want.
Keep on pluggin' away!
   / At Home In The Woods #2,136
attachment.php
Obed -
You're experiences are sure an eye-opener for myself, and I'm sure many others. At one point I thought I would sell the house we're in, and use the $$$ to build our retirement house, but now I'm definitely re-thinking that strategy.
Great news on the power, but 44 days is the first week in December.....do you think you can get an occupancy permit by then? I think you mentioned being in by Christmas before.....
You're very lucky to have a wife so privy to the construction processes and such a hard-charger.....it's like you have 2 GC's on the job! I'm afraid I won't be quite as lucky as you down the road.......
Anyways, you're doing great, keep plugging away and best of luck with timely progress!
Frank
   / At Home In The Woods #2,137
Obed -
Frank
Frank:
A lot of the issues Obed is seeing are regulatory, such as the 44 days, being able to live in the camper while building, etc.
This depends on where you are building. When my wife & I built our retirement home, we lived in a motor home on site all during construction, and no one ever gave us any grief over that. I spent a few months hauling water in in a 65 gallon tank, and hauling sewage out in another 65 gallon tank, until I got my water and septic for the house in. Once the well was drilled, we powered it with a generator and got our water that way. Between the pressure tank in the well house and the holding tank in the motorhome, I only had to run the generator once or twice a week for 20-30 minutes.
Once the septic was in we could use more water and life got pretty easy.
Our county didn't give us any grief at all about living in the motor home while building. They realized that after the house was done, we would park the motor home on the property and live in the house, but from the standpoint of neighbors, it didn't make any difference which one we lived in.
Our state/county worked differently than Obed's. Once we had the power to the house installed and the house dried in, we got a permit to turn it on for the workers to run their tools, instead of using a generator.
The whole idea of arbitrary time deadlines never came up...
   / At Home In The Woods #2,138
Around here they tend to let you power up one or two 20A GFI circuits once the panel/meter installation is inspected. Often the electrician will wire in a bathroom outlet or two for this at the same time they call for the panel/meter inspection so it is all ready to go. Then there is still a rough-in inspection and a final. They don't have to do the panel/meter inspection but will if you ask so you can get power on site.
One of those things that varies by region a lot...
   / At Home In The Woods #2,139
Obed, I think somewhere in the last 214 pages you mentioned where in Anderson Co you are, but I don't remember that. You certainly are outside any city limits, right? I know the people in Oak Ridge can really be puckerbutts, but are they influencing your inspections/permits? I'm thinking about building a house southwest of Clinton about 3 miles, but, man, your experience makes me want to just pitch a tent instead.
mkane09
   / At Home In The Woods #2,140
mkane09
Didn't he get in trouble with his camper too?
Tents might be against the law too.
tom
2007 Sterling Acterra Service Truck, VIN # 2FZACFDC67AY51272 (A57453)
2007 Sterling...
2842 (A54756)
2842 (A54756)
2008 Ford F-350 Lariat (A57148)
2008 Ford F-350...
2007 BIG TEX TRASH TRAILER (A58216)
2007 BIG TEX TRASH...
WIGGINS 5K FORKLIFT (A58216)
WIGGINS 5K...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
