Are we OK with how bright headlights are getting?
   / Are we OK with how bright headlights are getting? #1
strantor
Platinum Member
Brazoria co., TX
LS XR4140H
We all know the drill, driving at night, turn a bend and get blinded by oncoming high beams. You flash the other driver, they still don't turn off their high beams, so you just turn on your own and give it like you're getting it (or is that just me?) and a sluggish 2-3 seconds later they call a truce, turn off their highbeams, and so do you, and you pass each other like the civilized folk you should have been from the start.
That's how it's always been until the last few years when my constant-ON high beams statement is met with a flash from them, letting me know that "no, those aren't my high beams, THESE are my high beams" as they absolutely fry my retinas with brighter-than-the-sun cool white death rays. They make ME look like the a-hole (which maybe I am). When this first started I would wear that a-hole hat and say (not that they could hear me) "sorry, sorry, my mistake" and turn off my high beams, tuck tail and pass in humility.
But lately I am just almost not able to drive at night anymore and I'm reevaluating what the whole high-beam flashing exchange actually means. When you flash high beams are you saying (A) "I think you forgot to dim your high beams" or are you saying (B) "you're blinding the hell out of me and creating an unsafe situation?" I used to mean A. Now I mean B. And when I say B, it doesn't matter if your high beams are on or not. So I have started just blasting through the brighter-than-the-sun reply to my full-on frontal assault. I mean, it really makes no difference if they are blinding me at full power or half power, they are blinding me either way so I might as well return favor?
It's not like they went out of their way to install light bars and spotlights just to blind me, that is factory equipment. What message am I trying to send them?
"You shouldn't have bought a car with such bright headlights?"
"You should replace your headlights with some that aren't so bright?"
I guess so. I admit it's not 100% rational. My gripe really is with the manufacturers. How do I laser their retinas? Right now I'm trying to do it by discouraging the people buying their product but that's a losing battle and it's pushing me closer to having to admit to being an actual a-hole.
   / Are we OK with how bright headlights are getting? #2
My gripe with new car lighting is that the dash lights are always on. This results in countless idiots driving around at night with their headlights off.
Yeah that's in the city, I am usually driving at night in rural areas where you couldn't possibly not realize your headlights aren't on.
   / Are we OK with how bright headlights are getting? #4
You are not alone. Complaints from people about headlights that are too bright have been on the rise for a while now. LEDs are part of the problem, so is the fact that vehicles are taller putting the lights taller too. Complaints have led to recalls of some vehicles too as their owners say everyone is flashing them. Yes, some people don't dim their lights. :mad:
   / Are we OK with how bright headlights are getting? #5
It's a double edge sward for me. I'm getting to where I don't see as well at night, so I appreciate the bright headlights on my vehicle. But I drive a truck 99% of the time so I'm sitting high enough that most of the time I don't experience the negative side. However, I have had instances where I have blinded people with mine and could not help it. My truck does still have the old fashioned bulbs but they are mounted quite high. Lots of times when I pull a trailer they point too high, but are correct when I'm driving without a trailer. There is no provision for me to be able to easily adjust them based on load. I feel bad about it but nothing I can do really. Also, when I'm driving around town at night and end up at a light with a short car in front of me, or in a drive through I'm blinding them through their mirrors. Used to I would cut off my lights and just use my parking lights until I got out of that situation. Now with the auto lights it's hard to do that. I've had my truck a year and still can't figure out how to do that. The headlights are on at night, and if i turn them off the daytime running lights are on, and guess what, IT'S THE SAME DANG LIGHTS!
   / Are we OK with how bright headlights are getting? #6
I take advantage of it when I need X-rays for the Doctor.
I just put blank white paper on my seat back and go for a ride at night.
The lower extremities are a little tougher to get.
Hand and skull shots are eazy.:cool:
   / Are we OK with how bright headlights are getting? #8
NO NO NO
I can’t drive at night without someone blinding either on coming or from the rear…
The lamps can’t be legal as some pierce the rear view even when dim
   / Are we OK with how bright headlights are getting? #9
I don't the issue is as much with headlights too bright but rather poorly adjusted height on said headlights, which will blind anyone in front of them.
For instance, most Teslas come from factory with lights too high. When it's time for the anual vehicle inspection over here, they all get a type 1 annotation on the inspect sheet with the lights too high.
   / Are we OK with how bright headlights are getting? #10
This is definitely a "catch 22". If you're passing a new vehicle it sucks. But if you're driving a new vehicle and you can actually see the road (something that never existed before LED lighting) then it's amazing.
The issue is that the IIHS and NHTSA started considering headlight performance a safety metric, and they now rate vehicles based upon headlight performance. The fact is, if you have headlights that are terrible then it's dangerous to be driving at night. Many popular OEs including Ford, GM, Chrysler, etc. got horrible ratings on their lighting.
So now these OE designs are using LED or HID tech and they are finally putting out usable light. But….now people are complaining about how bright they are. It’s like there is no winning here. If they are too dim it’s dangerous, if they’re too bright older folks complain. What are the OE’s supposed to do?
I will never have a vehicle without LED headlights again. Game changer.
Generac 15KW Generator (A50860)
Generac 15KW...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
UNUSED 2-Pack Black Outdoor Patio Fabric Screen (A50860)
UNUSED 2-Pack...
2012 Ford F-550 Bucket Truck (A49461)
2012 Ford F-550...
2020 John Deere 9470R Tractor (A50860)
2020 John Deere...
UNUSED 30PCS Eye Lifting Hooks w/ Crane Hoist (A50860)
UNUSED 30PCS Eye...
