Anyone use the new bale trailers?
   / Anyone use the new bale trailers? #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
We keep seeing a new kinda bale trailer. It is essentially two rails set very high over a single axe. The bales look as if they'd roll off on a turn, They do rolloff quite easily when delivered, you just pop a lever and off they PLUNK.
Sure makes unloading easy.
   / Anyone use the new bale trailers? #2
I'm assuming what you described is a very common hay trailer in my area. They make both single axle "trailer" type and two axle "wagon" type. The ones I used were the wagon type and would carry five 5' bales at a time, and we would hook two of them together so we could transport ten 5' x 5' bales at a time. We'd load the bales from the rear and as you added a bale on the back end, just push all of them forward until we got 5 on. However, one guy in the area had a hydraulic hay handling device on the 3-point of his Ford that was not a spear. Instead of picking up a bale from one end, as you normally do with a spear, he approached the bales from the side and it had arms that clamped onto the ends of the bale, so he loaded the wagons from the side instead of the rear. His was the only one I've ever seen of that type. I never had any bales fall off accidentally although the guy I was working with had that latch come loose one day going down the road and dumped all 5 bales off into the borrow ditch. /forums/images/graemlins/shocked.gif You know it can be kind of awkward getting a tractor down into a borrow ditch to retrieve those bales with a Hay King bale spear on the 3-point hitch. /forums/images/graemlins/laugh.gif
   / Anyone use the new bale trailers? #3
Those hay bales can make a mess.
I was loading for a customer who was not hauling very far one day. I just stacked them in his trailer and he did not bother to strap them down.
In a hurry he lost one on a curve and took out a stretch of his fence. Not smart, particularly if it had been someones car.... /forums/images/graemlins/blush.gif
Fred
2019 Nissan Titan Crew Cab Pickup Truck (A55852)
2019 Nissan Titan...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A57193)
UNUSED...
UNUSED RAYTREE RMSC78 78" HYD SOIL CONDITIONER (A57193)
UNUSED RAYTREE...
2014 Kubota M8560D (A53317)
2014 Kubota M8560D...
Striker TNB-4M (A53317)
Striker TNB-4M...
2016 TEREX RL4-4 BULB LIGHT PLANT / GENERATOR (A52707)
2016 TEREX RL4-4...
