anyone modify the Kubota forks to pick up brush etc??
   / anyone modify the Kubota forks to pick up brush etc?? #1
donn12
Platinum Member
Great Falls Virginia
B2920 TLB turfs and loaded ags
My old tractor had a clamp on brush fork that was really good for small items and branches. My new tractor has the Kubota forks that I love but with only 2 big forks they don't do as well with loose debris. Has anyone added a brush grate or anything? I am thinking about trying to have a welding shop make something so any ideas or feedback would be appreciated.
I am thinking about 2 smaller forks outside and 1 between the two forks with spaces for the two big forks to slide through (one space at the front a few inches back and one at the rear).The big forks would do most of the work but the smaller ones wouldn't let stuff slip through. I also need to figure out how to keep the unit from sliding off so I can dump the debris. Am I on the right track?
   / anyone modify the Kubota forks to pick up brush etc?? #2
Just go to a forklift repair shop and buy a couple of old forks that have the same dimensions as the Kubota forks (they are standard skidsteer if I recall correctly).
Then you will have 4 forks of the same size. Much better for moving brush with 2 set wide and the other 2 set to divide up the remaining space.
Do you mean that the mount i standard? I think these are 3ft long. They are supposed to be for the B3200 but the QA bolts right on to the B2x20 series.
   / anyone modify the Kubota forks to pick up brush etc?? #4
The QA forks on a M7040 are the same as a standard skid steer. I can't be sure about your model but taking some simple measurements and going to a forklift repair place will let you know what is available.
You could take off one of the forks and haul it there to match it up exactly. The 4' length is more common and would be better for something light like brush on a lighter tractor. Four of them would work perfectly.
Also, Ritchie Bros. Auctions sells lots of skid steer attachments that fit up to my tractor very well. They often have complete forks (mount & forks) as well. But they usually go for $300-$400.
   / anyone modify the Kubota forks to pick up brush etc?? #5
Here are some photos of BX bucket forks (if you choose that direction) and a couple of skid steer attachments to give you an idea.
   / anyone modify the Kubota forks to pick up brush etc?? #6
The other option is to add a grapple to the pallet forks. By pinning the brush to the forks it seems to keep it from falling out.
   / anyone modify the Kubota forks to pick up brush etc?? #7
I made this. It works pretty good.
   / anyone modify the Kubota forks to pick up brush etc?? #8
I used some fairly inexpensive bale spears (Agri Supply) for my set-up.
The spears from agri supply may be the ticket! I will contact them and see if they will attach to the fork unit I have. I could add two of these to my forks and have a great set up . Thanks
TDVT - is everything the spears attach to custom made? The black plate the forks attach to looks like its factory so if so tell me where you got them. I thought they were mounted to Kubota fork setup before I enlarged the pic. Thanks
Giyi 72" Grapple Bucket (A57149)
Giyi 72" Grapple...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
PALLET FORKS (A58216)
Caterpillar 972M Articulated Wheel Loader (A56857)
Caterpillar 972M...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
TOYOTA 8FGCU30 FORKLIFT (INOPERABLE) (A58216)
TOYOTA 8FGCU30...
