anyone modify the Kubota forks to pick up brush etc??
   / anyone modify the Kubota forks to pick up brush etc?? #11
TDVT - is everything the spears attach to custom made? The black plate the forks attach to looks like its factory so if so tell me where you got them. I thought they were mounted to Kubota fork setup before I enlarged the pic. Thanks
I built the whole set-up as I don't have a quick-attach bucket. There's a thread around here with a few other pics somewhere.
The forks themselves use a "bushing" which is a pretty heavy-duty socket made for that particular spear. It has a tapered inside socket, so it gets quite rigid when it's tightened. The couplers are cheap ($7) & are welded (& gusseted) to the back side of 3" channel, which hooks over the top of the cross-member of the frame. I looked at alot of photos here for ideas. I just looked & don't have any pics of the back side of the forks but can take one if it would help. Since you already have a frame, I would just replicate the way the pallet forks attach & lock.
I constructed it like a fork frame so I can re-position the forks (or use only one or two) & also have pallet forks when I get around to making them. The frame also mounts on the 3PH though I've never used it back there.
I got the bale spear idea from someone else here & they've worked really well.
LOT: (2) Piece Mac Tools TRCH Portable 1000 Tool Box w/Contents: Lower Tool Box: 18-Drawers, Upper (A59076)
LOT: (2) Piece Mac...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A57453)
2016 Hino 195h...
2015 Ford Escape SE (A57148)
2015 Ford Escape...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2223EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
