Anyone know the part number for a FORD 2000 tractor, 1972 model 3 cyl gas
   / Anyone know the part number for a FORD 2000 tractor, 1972 model 3 cyl gas #1
shock
Bronze Member
Ford 2910
Looking for a part number for a starter for above tractor.
Anyone able to help?
   / Anyone know the part number for a FORD 2000 tractor, 1972 model 3 cyl gas #2
Take it off and have it rebuilt. Cheaper and comes back correct.
I have it off, no markings on it. I called a local rebuild place, but they were talking $150 to rebuild. I'd like to shop around to see if I can get one off Amazon as an alternative.
   / Anyone know the part number for a FORD 2000 tractor, 1972 model 3 cyl gas #4
Soundguy will know and can tell you the cheapest route to go. He will be around sooner or later- google it and see what comes up.
I have been Googling....lots of part numbers out there, most cryptic. I'll wait for Soundguy to chime in with suggestions.
   / Anyone know the part number for a FORD 2000 tractor, 1972 model 3 cyl gas #7
OEM number is D7NN11001A for a new starter. New Holland dealers can stock and sell D7NN11001AR which is remanufactured. A very popular new aftermarket starter part number is 1100-0112.
Excellent - Perfect - what I was looking for ! Thank you !
Well, since I have an ear, I might have been too assuming that it was my starter. Just assumed it was...but, I do need to go and have it tested.....Let me describe what's actually happening...Tractor is 45 years old. Owned by the same family for 43 years before I bought it, and I know the owners. It's the original starter.
9 times out of 10, when I hit the starter, there is a loud crack (sounds like metal on metal), and then I hear the freespin of the starter gear. Finally, on the roughly 10th time, the starter gear will engage the flywheel and turn the tractor over. Happens like this everytime I go to start it.
When I removed the starter, I didn't notice anything wrong with the flywheel like bent teeth or chipped teeth that would be a problem, nor did I notice anything on the starter gear...........again, assumed it was a starter? Is the described problem indicative of a starter going bad?
2000 PETERBILT 357 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
2014 GMC Terrain SLE2 SUV (A48082)
2014 GMC Terrain...
2013 Jeep Grand Cherokee SUV (A48082)
2013 Jeep Grand...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
