Front-End Loader anyone know of a tree spade for FEL?
   / anyone know of a tree spade for FEL? #1
RussMan
Jefferson City, MO (central)
B3030 w/ FEL and 72" midmt
I just built a house, so now is the time for fall landscaping. So I'm thinkin a few trees in the yard, but on Saturday's I would rather watch my Missouri Tigers play football than to be on the end of a shovel digging holes to plant a tree 6-7' tree.
I am thinkin there must be some sort of spade made that will attach to my FEL, so I can dig a hole easier and faster. Anyone know of such a device? Anyone have one to have opinion on whether they work?
   / anyone know of a tree spade for FEL? #4
The type MicroPilot shows would work with your FEL. The type mostly seen on skidsteers have 3 hydraulics operated "spears" that surround the tree. This type can be used on tractors but you may need a PTO operated pump as the tractor hydraulics will not handle the flow. Some of the bigger tractors may but most compact types won't.
WW
   / anyone know of a tree spade for FEL? #5
If you have a sturdy set of forks then consider the Quick Spade. It costs About $150 from Northern Tools. I have one and it works fine for digging holes up to about 4ft deep. It has an advantage over a BH when digging up plants because you can dig under them from the front and it is easy to manuver the tractor around as you dig.
They also make a version that fits just to the FEL bucket but that one can only dig about 18 inches deep.
   / anyone know of a tree spade for FEL? #6
I bought a Quick Spade based on Island Tractor's review (thanks). I had a couple of concerns - would it fit my cheap forks and would it work with a tooth bar - yes to both. It doesn't slide on to my forks for enough to be as secure as I want but it still works great. I'd buy it again in a heartbeat. Works great for popping stumps out and also good for pickin' the dirt out of the root balls so that I can burn them.
   / anyone know of a tree spade for FEL? #7
http://img.photobucket.com/albums/v145/supercobra/NH/032.jpg
http://img.photobucket.com/albums/v145/supercobra/NH/036.jpg
http://img.photobucket.com/albums/v145/supercobra/NH/037.jpg
http://img.photobucket.com/albums/v145/supercobra/NH/038.jpg
http://img.photobucket.com/albums/v145/supercobra/NH/039.jpg
That's a pretty impressive stump to have dug out with the quick spade. I haven't tried anything that big myself (I have a BH that I bring out for that size project). Nice to know the Quick Spade was up to the task.
   / anyone know of a tree spade for FEL? #9
I have WR Long's tree spade. It really works great...
   / anyone know of a tree spade for FEL? #10
This works SOOOooo good... KennyV
That is pretty cool. I have seen that brand for the skidsteers but didn't know they made a tractor version.
Do you have a QA set-up (I don't) or is that made to fit your pin configuration?
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2022 CATERPILLAR 299D3 XPS SKID STEER (A51242)
2022 CATERPILLAR...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
UNUSED CFG INDUSTRIAL PD680-PZ POST POUNDER (A51244)
UNUSED CFG...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
