Anyone here have bulldozer experience?
   / Anyone here have bulldozer experience? #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
I had a unit set up for last weekend with driver/operator. That fell thru.
I am considering renting a D-5 with 6 way blade and doing the work myself. Am I asking/expecting too much from myself like I had done with the wheel loader or is a bulldozer almost a no brainer cause its a tracked vehicle which Im assuming wont cut the highs and lows like the wheeled vehicles do so easily?
At this point most of the material ( sand central florida ) has been moved where it needs to be and now its the job of dispersing that sand more evenly than I would have been able to have done with the wheel loader.
I still also have a great amount of virgin material that I need to push from the R side of property over to the left.
I have no idea what to expect with using a bulldozer. I do not think I have ever sat on one even.
Nothing I cant do given enough time but looking for advice/opinions. Thanks
   / Anyone here have bulldozer experience? #3
Yes. It's not as easy as it looks!
   / Anyone here have bulldozer experience? #4
Sand is one of the hardest materials to spread with a dozer and keep it smooth. You having no experience even on a dozer could be a waste of money for you.
But smooth isn't as important as getting the material to the correct grade. Then you can use a tractor and box blade or back drag with the dozer blade.
If you push the blade control all the way forward it goes into free float, but you can't go forward with it in FF, just backwards.
If I was closer I'd been glad to help you out.. Good luck..
THE LGP dozers grade much easier than the narrow pads. So look/watch for that..
When you get aggravated take a break.. HAHA!!
   / Anyone here have bulldozer experience? #5
They are not hard to use,
it does take practice to become proficient.
An angled back drag can fix quite a bit of whoops.
   / Anyone here have bulldozer experience? #6
I ran a Cat D3B for a few years here on the farm. It will take a day or so to get the feel of it and then you will be fine. Ken Sweet
   / Anyone here have bulldozer experience? #7
I've been running one since I was about 13, and when I was in my 20's I was running an HD11 Allis, back blading.
An old dozer operator came over and gave me HE!!, and said "if you can't do it going forward, it can't be done!!" lol From that day on, I strived to live by those words!
Well, years and years later with a LOT of hours under my belt, I'd have to say.... he was right!! Just learn how to do it right in the first place, starting out by going slow enough to get it right, going forward!
SR
   / Anyone here have bulldozer experience? #8
I almost killed myself using a dozer.
It was a old Caterpillar with a pony motor, I don't remember the model. The lever for forward and reverse was backwards.
To go in reverse you had to push the lever forward. To go forward you had to pull the lever back. Tired at the end of the day I went too far on the top of the pile, and intuitive pulled the lever back hard, only to go over the dirt pile, the dozer almost rolled over.
It was probably the scariest things I ever experienced, made me feel sick.
   / Anyone here have bulldozer experience? #9
ive driven 3, one old D6 lever dozer - another D6 high track and a 963C. I have at least 2000+ hours running various skid steers and who knows the hours regarding different tractors, 100+ hours on excavators small to large 250class, and I will say i was humbled quickly on the dozers.
The lever dozer i lasted a day on it said screw it. The Hi-Track was better and the 963C was so much easier, pushing with dirt in the bucket was much like running a skid steer and the pedals/controls were much easier to navigate. Gouging was so much more avoidable with the bucket articulation. NOW, that being said they move totally different than anything you have ever driven unless you have spent time in a tracked SS vs wheeled. They are ROUGH, they are RIGID and unforgiving - you have to go slow, and then a little slower, you have to back up and try again many many times, I never did do worth a heck n the D6s with a straight blade, all i made were gouges and more bumps and it was frustrating. IF i ever rent another I will get a track loader for sure like a 953, 963, 973. We hired a company to build a mile of road for a subdivision we built and they only used track loaders no straight blades. Not sure why and they dug all the ponds and ditches with them also.
   / Anyone here have bulldozer experience? #10
For what you are doing a D-5 is a big machine to learn on. If you are set on a dozer get the smallest one you can. Depending on the rapidity of your learning curve, you will at least spend a good part or most of first day just getting used to the controls and the dexterity required. Like was said, sand is tough with a dozer unless you digging it out and building piling it up. Helps to have a tutor like I had first time.
Bert, I can identify with you. Cold weather we had to build a fire under it to get it warm enough to start. Always had ether ready. The old pony engines were also problematic with their hand crank.
Ron
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
BBQ Pit (A50860)
BBQ Pit (A50860)
UNUSED Life Proof SPC Luxury Flooring (A50860)
UNUSED Life Proof...
2025 K4230T UNUSED Metal Storage Shed (A50860)
2025 K4230T UNUSED...
John Deere Riding Mower (A50860)
John Deere Riding...
2007 Ford Escape XLT SUV (A48082)
2007 Ford Escape...
