anyone balast their own tires?
   / anyone balast their own tires? #11
a 4$ drill pump will work too.. and they are deffinately throw away.
PS.. cacl in granulated form can be bought by the bag as well.
No doubt but I tend to be impatient and this crappy little pump I have took about 3 minutes per tire.
   / anyone balast their own tires? #12
your call.. I have more time than money sometimes and I'd hate to toss a 38$ pump.. :)
   / anyone balast their own tires? #13
Tell you the truth SG I do not even know if it works. After I was done , I flushed it out with 5 gallons of water, put it in the box it came in an it sits somewhere in the garage where I left it that day. My intention was that I never wanted to see the inside of those rims again and with the money I saved ($500) doing it myself, I was happy with a possible $38 sacrifice. I do suppose I should drag it out and test it if just for the informational aspect for those wanting to purchase this Harbor Freight product who may use a pump such as this more frequently.
   / anyone balast their own tires? #14
if you flushed it good.. it may well be fine..
well i'm done the guy at the auto store was shocked when i bought 50 gals. of washer fluid but i got the fitting made by "slime" and it took me about 15 mins. per tire total and it made a huge difference. i appreciate everyones help and to anyone debating doing it yourself or paying someone it is quite simple.
   / anyone balast their own tires? #16
yep.. way cheaper to provide your own labor
   / anyone balast their own tires? #17
Yea I am still procrastinating the whole process, I have told myself that I will not load them till I put tubes in the tubless tires. The funny thing is I know how easy it is I have done several, I used calcium in those and that will never happen again.
   / anyone balast their own tires? #18
I filled my tires. Used a 12V boat bilge pump, farm supply store adapter, set of washer hoses.
This far north I used auto anti freeze and ww fluid tested to temps for this area........
My tires held 22 gallon each..... They are 33" turfs.....
Good luck
   / anyone balast their own tires? #19
Is there a good way to drain them? I'm looking at maybe picking up a set of turf tires to swap onto my B3200 for lawn mowing because I've been chewing things up pretty good with the R4' s - and I found a set for sale close to me - but they're loaded. I'm thinking I'd like to unload them to lighten the tractor up as much as possible if go this route.
Any idea what a set of 12.4-16 tires fully loaded weighs in at?
   / anyone balast their own tires? #20
Why mess with it. I hauled all 3 of my compacts to the local local tire dealer that sells rimgaurd, did it pretty cheaply, and did it right. No worries from here on.
2006 Ford Taurus Sedan (A55853)
2006 Ford Taurus...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
2020 DRAGON ESP...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
UNUSED FUTURE X.PG44 44" HYD PLATE GRABBER (A57193)
UNUSED FUTURE...
UNUSED RAYTREE RMA42' HYD AUGER (A57193)
UNUSED RAYTREE...
