Anybody hook up the reverse beeper on a RTV 500?
   / Anybody hook up the reverse beeper on a RTV 500? #1
DIXIEDOG
Platinum Member
Maine
International 2544 / Gator 825i/L2501/General
If so what wire is the reverse trigger wire? I want to hook up some backup lights but I'm not seeing a reverse wire on my electrical diagram but I'm assuming it must have one if they have a reverse beeper option.:confused:
   / Anybody hook up the reverse beeper on a RTV 500? #2
From the pictures ofd the kits for the 900 and 1100, they include a switch plate , wires and beeper. Do not thing thereis a switch mounted and you must get the kit to add it. I have some lights to put on the back of the 1100 and will just add a switch next to the front and rear work light switches.
David Kb7uns
OK, thanks for the info....I googled up some images after you mentioned it and that's not going to be easy. I guess I'll keep searching for a micro switch that will only make contact when my shifter is in reverse.
   / Anybody hook up the reverse beeper on a RTV 500? #4
If you can either get the kit or at least the mounting plate in the kit it would be easy.
David Kb7uns
2007 PETERBILT S/A 335 FUEL/ LUBE TRUCK (A57192)
2007 PETERBILT S/A...
20205 Lucky Dak Electric Scooter (A55853)
20205 Lucky Dak...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
2014 TAKEUCHI TB290 EXCAVATOR (A52707)
2014 TAKEUCHI...
2019 Kubota SVL75-2 (A53317)
2019 Kubota...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
