Any way to test for calcium chloride in tires for ballast?
   / Any way to test for calcium chloride in tires for ballast? #1
OHVarmntr
NW Ohio
JD 4600
I've had my JD4600 for less than a week now. It came with weights on each wheel and I just assumed it didn't have any liquid ballast so I didn't check the rims for corrosion. I was looking the tractor over tonight in the garage and one of the rims has some corrosion around the valve stem. I pulled the cap, pressed the valve core and low and behold liquid came pouring out. I went to the other wheel, and same thing. Both valve stems are at the 9 o'clock position.
Aside from tasting it (assuming it will taste like salty chlorine water?), are there any other ways to test the liquid to see if it indeed is calcium chloride?
Oh, here's a pic of the corrosion...
   / Any way to test for calcium chloride in tires for ballast? #2
Generally it is rather milky...it looks like salt water (duh I guess).
Hydrometer could determine the strength of the solution.
Otherwise hey, what else could it be other than maybe watered down windshield washer fluid (beet juice would be obvious beet colored).
   / Any way to test for calcium chloride in tires for ballast? #3
Put a puddle of it on the floor and get a dog you don't like to come and lap it up. If he lives, it ain't CC.:D (Just kidding everyone.)
Beet juice (Rim Guard) is very dark brown in color and has a smell that you won't forget once you smell it. It isn't all that bad mind you, but you don't forget it.
   / Any way to test for calcium chloride in tires for ballast? #4
My rims looked similar but a lot worse than yours. I promise you if you let this go for the summer you will regret it. :2cents: Have the tire removed and get rid of any tube in it. Clean the rim prime and repaint. Then have the tire remounted. I salvaged one rim and had to replace the other. I am happy with the Rim Guard but next time will probably use -20F windshield washer fluid. Half the fun of buying a used tractor is getting everything up and running nice.
I went a couple of years thinking I could just clean up the outside rusty area and all would be well. It wasn't and cost me. :mad:
   / Any way to test for calcium chloride in tires for ballast? #5
Corrosion does look like the result of a CaCl leak. CaCl is classified as an irritant, not a poison unless ingested in large quantities (actually you are more inclined to puke it up). But I would be concerned about other contaminants it might contained. After all it has been sitting in a deteriorating rubber container for who knows how long.
   / Any way to test for calcium chloride in tires for ballast? #6
Unfortunately you already know what is in that tire.
   / Any way to test for calcium chloride in tires for ballast? #7
   / Any way to test for calcium chloride in tires for ballast? #8
Spend the money Luke! You wont be sorry. Dismount the tires, scrap the tubes, clean everything up, repaint and install new tubes and add Rim-Guard/Beet Juice. Save the Calcium Chloride for the winter and put it on your snow/ice, or if your driveway is dusty this summer after grading smooth put the calc. on it, preferably right after a light to medium rain.
   / Any way to test for calcium chloride in tires for ballast? #9
CC is also slimy on your hands, nasty stuff that you will wash off. No other reason for a rim to rust like that.
   / Any way to test for calcium chloride in tires for ballast? #10
Prolonged exposure to CC and it will dry your hide out and you will be able to peel the top layer of skin off in sheets. How do I know? For 15 years I sprayed CC on dirt roads in early summer.
2009 Dodge Ram 3500 Flatbed Truck with Liftgate (A55973)
2009 Dodge Ram...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2015 DRAGON 130BBL VACUUM TRAILER (A58214)
2015 DRAGON 130BBL...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
