Any reason to check valve lash in YM2310? Anything else?
   / Any reason to check valve lash in YM2310? Anything else? #1
etpm
Veteran Member
Whidbey Island, WA
yanmar ym2310
My YM2310 is just over 40 years old. It runs great and starts easy in mid 40s temps. It smokes a bit when I increase the throttle, but only briefly. It will also smoke a bit when subjected to a heavy load but this also stops quickly once the RPM is back to what it was just before the heavy load. I do use some sort of moose pee, Power something or other, to treat the fuel. Besides changing filters and oils and greasing I have done nothing else to maintain the tractor since I bought it about 2 years ago. Should I even bother to pull the valve cover and check the valves? After reading about pulling injectors I will leave that job to whenever there is actually a reason to pull them. Is there anything else that should be done or checked?
Thanks,
Eric
   / Any reason to check valve lash in YM2310? Anything else? #2
Any idea how long since he valve clearance might have been checked?
   / Any reason to check valve lash in YM2310? Anything else? #3
Noise reduction, easier starting, and reduced component wear. When I adjusted the valves on a new to me Isuzu diesel with 260k miles, the engine noise seemed to be reduced to about half of what it was before.
Hi folks,
I don't know how I missed your replies from so long ago. I thought nobody had replied to my question. Please accept my apologies for the late replies.
Eric
Thanks for the reply. Because of what you and winston1 said I'm gonna order a valve cover gasket and when it gets here I will check the valve lash.
Thanks,
Eric
   / Any reason to check valve lash in YM2310? Anything else? #7
Hi folks,
Eric
When people reply without quoting the original message, you will NOT get notified.
You should be notified now as I did quote your post. ;)
Thanks. I didn't know that. I felt like a heel for asking a question and then neglecting to reply.
Eric
   / Any reason to check valve lash in YM2310? Anything else? #9
Eric
Don't worry about it! Now you can see what people were saying about you behind your back! :p
:p :p
   / Any reason to check valve lash in YM2310? Anything else? #10
Many of the Yanmars have a semi-permanent valve cover gasket. Sheet rubber on my YM240 (70's design) and fiber 'rope' in a groove, YM286D, about 1980. I think both are original. You might not need to buy one.
Be careful to get a thin putty knife under the gasket so it comes off with the valve cover.
Good luck with this! (y)
