An easier way to refuel your tractor
   / An easier way to refuel your tractor #51
I stuffed a Fil-Rite electric pump into the furnace oil (we heat with coloured diesel) tank and that works real good for me. No more handling 5 gallon cans and trying to lift them up onto the hood of the Kioti.
   / An easier way to refuel your tractor #52
Been using a rattle siphon for years for hydraulic oil and fuel. Simple and no mess. 5 dollars.
gg
   / An easier way to refuel your tractor #53
There are thousands of diesel fuel transfer tanks located in the back of pickups. They are made of metal vs plastic and are bonded to the vehicle. I wonder if being metal reduces the possibility of static electric?
   / An easier way to refuel your tractor #54
I use those No-Spill cans as well. My only gripe with the cans is minor: the spout is too short to make it easy to dump the last of my gas into the tank of our minivan or Subaru if I want to get rid of the last of any old stuff before refilling. (It does OK on our Tacoma pickup.)
No-spill sells an extension spout that makes filling cars and trucks easier.
   / An easier way to refuel your tractor #55
I don't know for sure, but I would guess that because the transfer tanks are secured / bonded / grounded to the vehicle is what makes them less apt to provide a means for static electricity to be generated.... Such a setup could be considered the same as the fuel tank built into each car/truck on the road - remember even if a vehicle has a plastic tank, the fill spout will be made of metal. I think where the issue of static electricity has a higher potential is when the transfer canister is NOT grounded to the vehicle and then is compounded when the canister does not have a metal fill spout.
I support my therory with the many documented examples of static-ignited fires involving ungrounded/fastened transfer canister (made of plastic construction) fires being loose in the back of a vehicle that also sports a plastic bedliner.... we know plastic supports static electricity. Whereas metal transfer canisters typically are not even painted at the fill opening, allowing for a grounding to occur when the metal fill spout is rubbed against it just prior to the start of the filling operation.
I think we all can agree that there are more vapors generated when filling/handling gasoline than there is when filling/handling diesel fuel...thus, less vapors with diesel fuel reduces the hazard, but does not eliminate it.
What do ya think, guys....does that make some sense?
BarnieTrk
   / An easier way to refuel your tractor #56
I personaly have never seen an electric pump, 12 volt or battery operated that goes on a jerry can. Kind of surprising. Probably, because someone would immeditely use it for Gasoline.
I bought this one a couple of years ago. The ad claims it's approved for gasoline but I don't know what authority "approved" it.
https://www.amazon.com/gp/product/B01HOXQ5E0/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
I do use it to fuel a generator from a 5 gal. can but I make the electrical connection at least 50 feet away.
   / An easier way to refuel your tractor #57
I have one of these will easily pump from a can on the ground up into the top mounted tank on my jinma
ALEKO BST1017N 12V 5A DC Motor Fuel Oil Diesel Pump with Hose with Handle
   / An easier way to refuel your tractor #58
Can usually be found on Amazon for under $20 will empty a 5 gal can in about 2 min never timed it but pretty fastpump.jpeg
   / An easier way to refuel your tractor #59
I got this https://www.northerntool.com/shop/tools/product_200609589_200609589
Its a bit expensive but I just hook it up to my tractor battery and fill it up. I put it on a pallet so can load and unload in my truck. I also use when I rent an excavator. Makes it really nice for that. Plus its 55 gallons.
Its handy and the pump works great.
As I said probably a bit expensive but I don't regret purchasing it
   / An easier way to refuel your tractor #60
I like the way that they say
Made for motor, diesel, or heating oil. Do not use for water, gearbox oil, or easily flammable liquids like fuel or petrol.
, then go on to tell how you can use it to fuel your
Car, Motorcycles, Scooter, Quad Bike, Truck, Boat, Forklift, Generator, Tractor, Ride On Mower
Still, it looks like a handy tool for diesel and I will have to try one. I just dumped 8 gallons in using a rattle hose and while it works well I am always open to a better way.
Case IH Maxxum 150 (A53317)
Case IH Maxxum 150...
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
2007 Club Car DS Gas Cart (A55853)
2007 Club Car DS...
FRONTIER 3 PT HAYSPEAR (A57192)
FRONTIER 3 PT...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
John Deere 853 20ft Corn Head (A55315)
John Deere 853...
