aftermarket turbo kits
   / aftermarket turbo kits #11
I have a Ford 1720 which for me is perfect in all respects except HP.
I installed a turbo last year after quite a few years of thinking of a bigger tractor & wanting more HP but reality set in as not being affordable.
So a new bigger tractor was not going to happen for me.
I happened to find a turbo at a swap meet which looked to be the right size so I bought it.
It now has the extra power I致e always wanted without the added size & weight of a bigger tractor.
It has considerably more hp to muscle thru tough sections when mowing or snow-blowing and will generate 10 psi boost but I limit it to 4~5 psi for continuous operation.
There are photos of my turbo installation in the review section under Ford 1720.
This tractor has a 1.5 liter (90 ci) engine that originally put out 27 hp gross!
I知 quite sure it isn稚 being stressed even if it痴 now generating 40 hp.
Now it better fits my needs.
Could it fail possibly; but if it breaks I値l fix it!
yelbike
You ask;
Why would you want to put a turbo on a tractor? Just buy a bigger tractor with more hp.
I値l ask why not? Perhaps money is an issue or perhaps the tractor is perfect except for hp.
The 1990 Dodge Diesel pickup originally generated 160hp. Just changing the turbo and increasing the fuel rate they can reliably generate over 600hp.
   / aftermarket turbo kits #12
Of course, with a turbo you also get greater economy.
   / aftermarket turbo kits #13
I'm guessing most factory engines are built much stronger than they need to be and adding a few pounds of boost wouldn't hurt them. If you are at the Kubota dealer or if you have the parts manual you could look at the 4740, 5040, 5240, and 5740 to see what differences there are. I believe they all have the same size displacement. It could be nothing more than the amount of boost. They may have the same pistons and turbos (or maybe a larger turbo for each model).
   / aftermarket turbo kits #14
yelbike
You ask;
How do you know what it's putting out? Did you dyno it? that's the only way to really know.
And an engine that put out 160 Hp didn't go to 600 hp with just a blower and more fuel. There was a lot more engine component change involved than just those two components. And the driveline had to be beefed up considerably. If you believe just a blower change and overfueling made 440 hp increase, then you probably think a Chevy NASCAR engine comes off the Chevy assembly line and goes straight to the race!
I don't want to belabor the point I was trying to make in my initial post on this topic but remember, an increase in torque at the engine ouput shaft is multiplied many times throught the reduction gearing of the the drive line. That so called "little" increase in engine torque is multiplied by the overall driveline gear ratio and gets to be a larger torque increase with every reduction in driveline speed. Sure there are load margins in the design but there is always a weakest link somewhere. And you do't know what th design margins are. Statements like " the engine is made stronge than it needs to be " or this is a tractor, it's can take it" etc are just wishful thinking. Is it going to break in a few hours? Probably not. But, redoing the driveline is more expensive than rebuilding an engine and you'll be taking life out of that as well as the engine.
As I said before, your $'s, your risk, your call. I'm just trying to point out potential pitfalls. Most of us value durability and reliability in our tractors. But it's a free country so we can make individual choices. The more information we have , the better choices we make. 'Nuff said!
   / aftermarket turbo kits #15
Perfectly said.:thumbsup:The extra HP is paid by a decrease in reliability. It likely won't fail tomorrow though. Your machine and your money.
   / aftermarket turbo kits #16
My "guess" is that as long as you have a normally aspirated engine that is also offered in a turbo version things should be OK if you just add the bits that the alternate model has, i.e. MODEST boost to a level that is acceptable for factory warranty - although of course you will have NONE.
Whether or not anyone has sat down with the parts books for your engine and its alternate incarnations to make up ready for sale kits - is a whole 'nother question
This is kinda/sorta how Banks kits used to be, as I recall they eventually became factory options and at some point were fully integrated into the model line - GM 6.2 N/A to 6.5 T
   / aftermarket turbo kits #17
You know what, to each and one their own. Personally I'm always looking for more power out of whatever I have. "Turning something up" and the reliability of that machine afterwords all depends on how it is serviced, how it is used, and who is at the wheel. As long as you have sense, then the additional power derived from enhancements can be appreciated. Manufactures limit power due to those that do nothing but abuse or simply are idiots when it comes to using a piece of equipment. But as said earlier, to each and one their own.
   / aftermarket turbo kits #18
Besides adding a turbo for more power, have you though much about the extra heat generated? For short term loads, it is most likely not a big deal, but continuous heavy loading might easily cause overheating.
   / aftermarket turbo kits #19
And from what I understood from J.D. the difference between my 3320 and a 3520 was the turbo. Engine was exact. I couldn't see the extra expence when I didn't neet it. If I do in the future it will be added without a doubt. One of the reasons I bought that engine/tractor was a turbo could be added without any engine problems.
not true. the 3320 actually has a bigger engine than the 35 or 3720.
they make the power off of the turbo on the 35 and turbo and the intercooler on the 3720
2143 (A58376)
2143 (A58376)
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56438)
2014 Doyle Dry...
2018 Knap Heide KTEC88-McCoy24.5 SP Flatbed (A58216)
2018 Knap Heide...
2014 Bobcat S185 (A57148)
2014 Bobcat S185...
