Aftermarket or good 12" Front wheel rim to fit Mahindra Max26/28 needed?
   / Aftermarket or good 12" Front wheel rim to fit Mahindra Max26/28 needed? #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Comical what Mahindra direct dares to ask for a tiny 12" steel rim. These rims have a 80mm center hub fit diameter, 5 lug bolt holes, 1/2" holes on a 4.5" bolt circle, fits 23x8.5-12 R4 tire.
Does anyone know where I can get a useable rim?
   / Aftermarket or good 12" Front wheel rim to fit Mahindra Max26/28 needed? #2
Try TSC. The width you will need probably makes it special.
It is the 80mm centering hub fit that is the problem. The most common is 3" that I can buy on Amazon, but it would be a lot of careful grinding and trial fittings to open to 80mm.
   / Aftermarket or good 12" Front wheel rim to fit Mahindra Max26/28 needed? #4
For a low speed application I dont see any need to worry about the center - just make it big enough. The lugs, esp if tapered, will hold the wheel securely. -- The fronts on my 7520 with loader do not use taper lugs, yet do not move on the hub in the slightest, even though there is some center hole clearance.
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
Deere 310L (A53317)
Deere 310L (A53317)
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
2016 Hyundai Tucson (A53424)
2016 Hyundai...
2011 MERCEDES-BENZ S-Class Sedan (A53424)
2011 MERCEDES-BENZ...
Man Basket Forklift Attachment (A55851)
Man Basket...
