After Only 5+ Years, The Tank Outlet Clogs
   / After Only 5+ Years, The Tank Outlet Clogs #1
SnowRidge
Elite Member
East Tennessee
Power Trac PT-425 / Branson 3520
My PT-425 quit on me today. Turned out to be the elbow fitting on the bottom of the fuel tank. It was clogged. I also saw a few strands of scum floating in the tank, something I have never seen before. I think the 10% ethanol "gas" is behind this nonsense.
I've noticed a couple of stations with big signs proclaiming their fuel to be 100% alcohol free. I think next time I buy gas for the PT, I will try the alcohol free stuff.
   / After Only 5+ Years, The Tank Outlet Clogs #2
Can't say I have run into scum in gasoline, diesel yes. I would think that the gasoline with ethanol would actually be better at preventing this as the alcohol acts just like adding ISO Heat fuel antifreeze/dryer. It would help to remove water from the system.
Alcohol can attack certain materials that are impervious to gasoline, including some plastics and some metals. While today's automotive fuel systems are designed with this in mind, it isn't clear that is the case with all power equipment.
   / After Only 5+ Years, The Tank Outlet Clogs #4
Do you think the scum was organic, like algae, or dissolved plastic, gaskets, etc...?
I'm not sure, Moss. It was/is a couple of brownish strands floating in, not on, the gas. I don't even know if it was related to the clog. I was loading a trailer when the machine died and needed to fix it fast. I noticed the fuel filter was empty, disconnected the line at the filter, and ran a thin wire up it to and into the elbow to clear it. The only thing visible that came out was gas.
If PT used any fiberglass resins in their tanks...you have a problem...
BoatUS.com - Seaworthy Magazine
Oh, that's ugly.
I'm not sure what PT tanks are made out of, but I know mine isn't fiberglass. It appears to be polyethylene. It leaked from day one, and I had to use a sealant under the filler neck to cure the leak. The alcohol may be reacting with something in the sealant.
   / After Only 5+ Years, The Tank Outlet Clogs #8
Dear SnowRidge,
There is the possibility that your new fuel dissolved something out of your gas tank, but if you haven't been seeing fibers and debris before, I would bet on the fuel. Any petroleum fuel is susceptible to growing bacteria. Often the bacteria grow best on the interface with water at the bottom of many underground tanks. Over time, if the station isn't actively trying to remove the water, you can get substantial accumulations of fibrous material from the bacteria. Obviously, if you get the gas from a station that has new tanks and does a lot of business, you are less likely to get into trouble. Oh, and it helps if you get the gas in an area with low dew points, like Arizona. :)
In general, it is much more of a problem for diesel fuel which is much more hydroscopic than gasoline.
If you have the misfortune to get fuel from low in the tank, or just after a tanker delivery has mixed it up, you can get a slug of this material. You can also get debris because by the gas station switching to a higher ethanol blend E0 to E10 or higher. The ethanol dries up the water, and the fibers are set loose in the gasoline. The ethanol is also good at dissolving up material that has precipitated from the gasoline. (Good for you in the long run, but not if the gas station switches to the higher ethanol fuel without cleaning out the tanks.)
Gas stations are supposed to flush and clean their gasoline tanks when they switch to E10 or higher ethanol mixtures, because the ethanol is very good at dissolving sediment and gunk from the bottoms of gasoline tanks. Some states mandate this, but not every state.
Regardless of the cause of the sludge, you were probably unlucky enough to get gasoline from a station that hadn't flushed their tanks.
It is a general problem for gasoline tanks;
US Tank Alliance | Tank Cleaning and Ethanol Conversion
but an abrupt change to E10 or E85 without cleaning can dissolve up a lot of gunk.
I also try not to get gasoline right after the tankers make a delivery for similar reasons; who needs to have extra gunk washed into your tank, and your fuel filter?
Given all of the vapor lock issues with the 425, I wouldn't be rushing to put E85 into the tank, despite its advantages for carburetor and tank cleaning, because of the higher vapor pressure and the increased octane, neither of which you need.
All the best,
Peter
The gas was from a brand new station. They just built it. It had been open about a month when I filled my collection of jerry jugs.
   / After Only 5+ Years, The Tank Outlet Clogs #10
Well that blows that theory. Nothing like reality to ruin a good theory. :)
Since your tank is polyethylene, it is hard to imagine that it is from the tank itself, unless it was the sealant that you used originally.
Did you have to change the fuel filter as well? And for my money, you should see anything floating around in your fuel...
All the best,
Peter
2025 K4525 UNUSED Double Garage Steel Barn (A50860)
2025 K4525 UNUSED...
Hustler Super Z 72 Zero Turn Mower (A50860)
Hustler Super Z 72...
2012 Ford Fiesta SE Sedan (A48082)
2012 Ford Fiesta...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
