I bought a Mahindra 5555 a few days ago, it came with a 7ft bush hog. I advertised locally offering bush hog work and driveway maintenance, to my surprise I have gotten many folks needing bush hog work done locally.
What advice would you give someone thatç—´ never ran a bush hog before? Walk the field first? Run with bucket down? Take pallet forks off and put on a bucket?
What size tree is too big to hog? At what point do I bring a chainsaw? Do I keep a saw on the tractor? When is a field to far gone and itç—´ just land clearing at that point? What to charge for land clearing?
What advice would you give bidding jobs? Written or verbal contract to mow? What kinda insurance if any?
I don稚 have a trailer, how far would you run the tractor on the road? 5 miles? 10 miles? 100 miles? Not wanting to eat my tires up for a few hundred bucks but farmers run on roads all the time and get a long life out of tires. (I have R1 tires on my tractor)
Thanks for any and all advice.
You have a lot of questions, and they are mostly good questions. I brush hog over 1000 acres per year along with farming a lot of hay. I started in a similar way to you, but didnt advertise much. I run 2 130HP tractors and 2 Deere CX15 folding mowers with CAT 6 drive lines.
I try to walk any new fields I do first, before bidding. Wear tough shoes and long pants and spray to avoid ticks.
I wouldnt be opposed to running with a bucket on a new field. Keep it about 10 off ground curled all the way back and use it to feel for stumps or objects. Once I know the field, I remove the bucket, but keep loader on for pushing downed trees away or brush down and protecting front of tractor. Can also save your butt if you get stuck.
The size of the tree you can bush hog depends on the grade/gear box/driveline of your bush hog. Look your model up and see what it can handle. Mine will handle up to 4 inch material, but I rarely have used it to do that. I would cut the tree down first with a saw. I will back over 2-3 inch material carefully then grind it up.
I keep a saw on the tractor most times, especially on new fields. Handy for fallen trees on existing/known fields and gives you the opportunity to make a little more money along the way. I keep mine in the cab. I also keep an older gas powered blower bungee corded to the bush hog deck to clean debris off mower when Im done.
When you say what to charge for land clearing? I would say thats a totally different business. Land clearing usually involves chain saws, Fecon style mowers mounted on tracked skid steer and a tub grinder to chip all the debris up. Are you going into the land clearing business? Thats a pretty expensive undertaking and a step above field mowing and brush hogging.
As far as bidding, thats up to you, but right now I charge $150+ per hour. I am running 15 mowers on 130HP tractors, so I can cut more and faster than your set up. When I first started 20 years ago, I had a 75HP tractor and a 8 twin spindle mower. I charged about $100 per hour. Whatever you do, dont undersell yourself. I can guarantee you you WILL break things and get flat tires. Make sure you save some of your earnings for future repairs. And while we are on the subject of tires DO NOT fill tires with liquid. You WILL be sorry. Use cast center wheels/wheel weights.
Yes, you MUST have insurance if its a business. Its irresponsible not to carry insurance. Its part of the cost of doing business.
I Road all machinery within 10-15 miles. Anything further and I usually get on my trailer. All depends on available road conditions. I can run on back roads that are much more dangerous than driving in a straight line down a 4 lane highway for 15 miles. Make sure you have lots of lighting 4 way flashers on and SMV emblems on mower.
R4s are ok tires, but for bush hogging as a business, I only run R1s. They get far far better traction and youll need it on soft or sloped ground.
