Buying Advice Advice on First Utility Tractor Purchase
   / Advice on First Utility Tractor Purchase #1
mikema0477
Framingham, MA
None
I have about 1.5 acres. 0.5 acres is lawn. The rest is wooded and is currently overgrown by brush, trees, etc. I will probably have the opportunity to purchase 1 or 1.5 more adjacent acres in a few months and will probably do just that.
I need something that can move rocks...lots and lots and lots of rocks. The land is full of them, the majority of them exposed in some sort of way to make maneuverability a stinking mess. You can get a hand on most of them, but you would still need to dig them out. From reading the forums the majority of the advice seems to be to hire/rent a large industrial-size machine to move rocks around (and I plan on doing just that to move some of the gigantic ones), but believe me when I tell you I will be working on digging rocks out of the ground for a long long time. I want to stack a bunch of them to create a retaining wall...figured I would need a backhoe for that.
I am also going to need to do your normal brush clearing and stump removing activities and something that can drag large (12"+) downed trees to a staging area for a chipper.
I also see the need to hitch up a trailer or a smaller chipper to take into certain areas on a fairly regular basis. If that is the case should I forget about getting an attached backhoe and just purchase one of those towable backhoe products?
I also need something that I can use to clear snow from about 300ft of driveway.
For the most part I think a Kubota BX25 would do the trick, except for one thing: ground clearance. But it looks like the B series has more ground clearance which I think would be really beneficial given the rocky terrain. Is it worth the extra cost? Also would I lose a lot of maneuverability with that? And it looks like it has a stronger backhoe which could make a difference. I know what the stat sheets say but I am hoping to get some real-world evidence here.
Any advice you folks can offer would be appreciated. I should also note that I am not stuck on Kubota. Any other suggestions on make/models that you think would do the trick can help. We have a Mahindra and JD dealer that is somewhat close and a Kioti dealer about 1 hour away.
   / Advice on First Utility Tractor Purchase #2
Welcome to TBN!
Rocks are a challenge if they are large. I wouldn't recommend a tow-behind backhoe. It doesn't take very long to remove/attach a backhoe from most tractors when you need to use a chipper of other 3pt tool.
Some pics of the rocks would help. For wall stacking rocks heavier than you want to lift, a hydraulic thumb on the backhoe bucket is a good thing. That would allow you to pick up and place a rock with reasonable accuracy.
Without pics I would think you want something more in the Kubota L series size. You won't beat up a larger tractor as much as a small one and it will reduce your rentals and the hassles that come with that. You can always drop back to a smaller unit once the heavy work is done, if that ever happens. :laughing:
Thanks, Dave. I will have to get some good pictures tomorrow. It looks like the moon in some places!
I should have mentioned that storage/price is an issue, so I think the L series is out unfortunately.
   / Advice on First Utility Tractor Purchase #4
I would suggest something much larger than your BX 25. Sure, it comes with a backhoe and doesn't take up much space but when dealing with large rocks and stumps, its just a toy. If you need convincing, find a rental in your area and try one out for a day. Now consider a machine that will allow you to accomplish something daily, like a Case 580 tractor/loader/backhoe (TLB). Used ones are very common and reasonably priced. Most people use them for a specific job and then resale them once finished. The older ones without 4WD and an enclosed cab are available and cheaper. Things to check are easy starting and strong engine, shuttle tranny is tight and look for leaking hoses and cylinders. It is also a machine that you won't break the first time you use/abuse it. Probably buy one cheaper than a BX 25. Happy digging!!!
   / Advice on First Utility Tractor Purchase #5
Those pesky details are usually an issue but not a game stopper. :) BX's are tough machines, I don't really know enough to compare the B30 to a BX for backhoe work.
The moonscape can be deceiving. It could be not just a layer of rocks that you can see on the surface, there may be more rocks below. About all you can do is try to pick a level that all the protruding rocks fall below by enough that they don't stick up too much. Add some fill dirt here and there if needed.
Also, since you have BIG rocks around that you know of, it's hard to know if the top of a rock you see at the surface is a one footer or a three-four footer.
A hand tool I have found very useful with rocks is a 6' long heavy hex bar. They weigh ~20 pounds, have a chisel shape at one end and a round point at the other. You can pry and scoot good sized rocks with that leverage. It's a great back and finger saver. You should be able to find one at Home Depot or the like.
   / Advice on First Utility Tractor Purchase #7
I'm in agreement with Halftrack that you will be better served with a full size TLB with a thumb. Pulling rocks out the ground requires weight to keep the machine anchored so your not pulling yourself all around the yard. If it was me I would rent to get started and move the larger rocks. Get a couple of helpers as well. Sounds like a fun project. Good luck and enjoy!
   / Advice on First Utility Tractor Purchase #8
Removing rocks is a long term project. I would look to buy a used 580 commercial grade backhoe and then sell it if you no longer need it.
The reason I say buy is from personal experience. I recently started removing the small rocks (mostly less than 100 pounds) from a garden spot that is 40 x 100 and I worked on it for 3 weeks (half day at a time due to the heat) It takes much longer that anticipated as they just keep appearing.
You can find older 580 Case machines everywhere, they are a popular brand for construction sites. My house building contractor bought one in fairly good shape, not oil leaks and strong engine but a little loose in the hoe for $8000 here in Arkansas. Around here you can find lots of them for sale, some with a nice cab for $12K. They are easily resalable also. But if budget allows, just keep it because you are going to find more rocks later, guaranteed.
A hydraulic thumb is almost a requirement for lifting and placing rocks of various sizes and that may be hard to find in a commercial grade machine.
I love my B26 that I bought used slightly,68hours, for $20.5K with hydraulic thumb but it wont lift rocks larger than about 250#, not due to lift capacity, but due to size as it just cant get a grip on them. A 580 would handle some pretty big rocks. A manual thumb might work but be prepared to dismount a lot to adjust to various sizes of rocks. With the hydraulic thumb, I can pick up rocks as small as a baseball up to about 18" without leaving my seat.
Thanks for the advice everyone. I'm probably not going to be able to swing buying a full size TLB...will take some convincing of the wife on my part plus I will still need something to do the smaller jobs I referred to as well.
Here is picture of the worst part which is reflective of most of the property. From what I am hearing it sounds like I should rent (or hire a guy) a good sized machine to move the bigger rocks. When I say "big" I'm referring to rocks the size of the one in the left of the picture. I probably need to move about ten of those total no more than fifty feet. It's the medium and small size ones that I am going to try and do myself. 20140922_091916.jpg
Do you think I could move those with a B-series? I'm not really in a rush.
   / Advice on First Utility Tractor Purchase #10
With a property like that, I wouldn't even look at buying a tractor. I would get a Compact Track Loader or a Multi terrain loader. I have been doing rock work for a couple years, and I have been using a Mini Excavator tractor combo for a while. Both work great, but I would never just want the tractor. I have done that and It isn't fun, and with a bx25 it REALLY wouldn't be fun. I had a Jd 2320 with a 46 backhoe. It was an Amazing tractor, but the backhoe couldn't pull stumps out bigger the 4in. I know how to run the backhoe and how to baby it, its just didn't have the power. If I were you, I would buy a multi terrain loader like a Cat 247, and get a bucket, pallet forks and a rock grapple. With that combo you will be very happy. And when you need to dig, rent a mini excavator. Thanks, John
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
Horizontal Hydraulic Wheel Press (A59213)
Horizontal...
John Deere 6110M (A53317)
John Deere 6110M...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
