Traction Adding water to rear tires
   / Adding water to rear tires #11
Even in PA, it is likely you could get away with just plain water if your tractor is in a heated garage, as it takes many hours to freeze a volume of water like a tractor tire. Also being black they will soak up sunlight and produce heat even in freezing air. And likely being back in a heated garage at night it would likely never freeze unless exposed to long term outside usage in cloudy conditions (oh yeah wintertime:)) The ingredient that you are interested in in WW fluid is Methanol aka Methyl alcohol. You can buy this in bulk and mix with water to make your own solution.. You don't need any ammonia as you are not trying to clean bugs off of glass.
James K0UA
It's not a heated garage but nothing ever freezes out there or at least not yet. I didn't want to use the methanol because it is toxic, ammonia isn't toxic. There is also a formula that uses rubbing alcohol which shouldn't be toxic. I just want to add some weight, not have to install tubes, and not rot out my rim Rim Guard is just so expensive it weighs more but that is expensive weight. Yea I could probably just use water and get away with it but I would like some protection and also trying to help out the OP at the same time.
UNUSED FUTURE P45 56" HYD BREAKER HAMMER (A57193)
UNUSED FUTURE P45...
2014 Ford Fusion (A56859)
2014 Ford Fusion...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A57024)
2019 BOBCAT T630...
1999 Kubota L2500D Utility Loader Tractor (A55851)
1999 Kubota L2500D...
2020 CATERPILLAR 239D3 SKID STEER (A52707)
2020 CATERPILLAR...
2025 Ligchine Spiderscreed Concrete Screed (A55851)
2025 Ligchine...
