Oil & Fuel Add 20 year old oil to motor?
   / Add 20 year old oil to motor? #12
I had a sample sent in for analysis from a drum of oil I purchased at an auction. It was labeled Pennzoil Multi duty. Turned out to be just old standard machine 30w oil. I used it for years in my Ford 1900 Diesel without any issues. Sold the tractor and still have some of that oil in the drum. I would only use it on equipment that could use that 30w and in my case it's a couple of small engines I still have laying around. I will eventually use it all up but probably will be 90 by then. The analysis of the oil came back that it was fine as the drum was sealed for years and all of my years too. Oil won't go bad but like mentioned this one has no additives in it basically. Simple machine oil.
   / Add 20 year old oil to motor? #13
They have made a lot of improvements in oil since that was made, it’s probably gotten hot and cold several time, and I’d still go ahead and use it in a small engine and not worry.
   / Add 20 year old oil to motor? #14
... I’d still go ahead and use it in a small engine and not worry.
Yeah.
Listen to Ralph above (Post #11). If 20 years ago spec 10-30 oil could cause damage in a simple application - in 30 years as a lube oil engineer, Ralph would have heard about it.
Not a problem.
   / Add 20 year old oil to motor? #15
Using old oil was better than nothing. However, I take a divergent view than the others.
Oil additives begin to lose their effectiveness in five years. OK to use in a low value motor, especially mixed with a greater quantity of new oil. But do not use by itself, and I'd not use it in an expensive motor. Good that you shook the container - any additives that separated, were remixed, and fully poured from the container.
I’m under the impression that the oil breakdown occurs due to heat, and absorption of moisture from the air. That a sealed can of oil, should last almost indefinitely.
If I’m wrong educated me.
   / Add 20 year old oil to motor? #16
I was using metal cans of oil for the outboard from the 1950's
Had one of my old car friends with me one time and he said what are you doing???
I sure got a scolding but not for what you thought.
He said he could sell all I had at $25 a quart full or $10 a can empty to collectors... this is 10 years ago...
   / Add 20 year old oil to motor? #17
Oil, is better than No Oil
shouldn't be a problem, still a fresh can
   / Add 20 year old oil to motor? #18
Has anyone here seen harm from bad oil? (Assuming a recognized brand, not contaminated, or incompatible with modern emissions).
   / Add 20 year old oil to motor? #19
That's good to hear.
I have two quarts of Castrol GTX in the old qt cardboard sided cans with metal top and bottom that were in a box I bought at an auction 20 years ago.
I have saved them all these years thinking exactly what your friend's thinking.
24637 (A55853)
24637 (A55853)
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
Hustler 62in Zero Turn Mower (A55851)
Hustler 62in Zero...
2025 Wolverine MAD-12-12D 36in Auger Skid Steer Attachment (A55851)
2025 Wolverine...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
