Aaaarggggh! I broke it! Help!
   / Aaaarggggh! I broke it! Help! #41
</font><font color="blue" class="small">( love that short section of chain)</font>
I'll say ! I made mine just a tad longer than yours - when I use them forward they come just to the front edge of the bucket where most folks weld 'em on - and when I hang them down the back they come to just at or just below the "heel" of the bucket. In the "fridge" thread they were there because just before & after I had used them to move a 250 gallon propane tank. First chaining the tank into the bucket frontwise for tansport - then suspending the tank under the bucket for positioning it onto concrete pads. And when I'm not using them - they're in the toolbox out of the way yet handy to grab. Everytime I use 'em I say "thanks jim" .... stealing ideas sure is easier than tryin' to come up with 'em on yer own.. /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
   / Aaaarggggh! I broke it! Help! #42
I agree w/ jerry... put a spacer in there, and put it in a vice, and heat it a little, and bend it... that is steel not cast iron.. should be safe there.
If you don't like those lynch pins, try a toplink pin with a cotter key.. though that lynch pin design is pretty much the standard in aggricultural services.
Soundguy
   / Aaaarggggh! I broke it! Help! #43
Guys,
One idea that comes to mind is:
Some of my cat 2 pins are basicaly a metal pin without a head at all. The one end has the normal hole for the snap ring pins shown above. But the other end has been drilled and then a very solid pin is fit into it at a 90 degree angle. This second pin does not come out.
So if you have a problem with the hole in your cat 1 implement being two large or irregular a simple solution would be to drill a hole in an exsiting pin at the end with the head and install a small rod ~1"-2" long. If you have a welder you could weld it togheter. This rod, which should be hardened steel will make sure the pin never slips out again.
My Cat 2 blade uses this type of pin and it has never been a problem. Very heavy implement with a lot of stress due to ground engagment.
Fred
Hi Fellas, Sorry for the delayed comments. Lightning fried my modem, got it fixed, and then we had two major power outages here in the NE. I was literally in the dark for awhile.
I took the easy way out with the top bracket and got a new one from Corriher (no charge). For the top link, I've switched to the hitch pins with the red "D" handles (from TSC) which uses a "hairpin" which I insert all the way in. For the botom links, I've switched to a much stronger "black" linch pin (from TSC), AND I am much more vigilante when using a 3 point implement. I look back and check all links frequently!
Bruce
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2007 Chrysler Aspen SUV (A56859)
2007 Chrysler...
1323 (A58374)
1323 (A58374)
LOT: Assorted Clamps (A59076)
LOT: Assorted...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
