A deer story
   / A deer story #1
RobertBrown
Veteran Member
Florida
Bolens G192/TS1910 Ford/New Holland 1920
Reported to be a true story by a no so bright farmer.
I had this idea that I could rope a deer, put it in a stall, feed it up on
corn for a couple of weeks, then kill it and eat it. The first step in this
adventure was getting a deer. I figured that, since they congregate at my
cattle feeder and do not seem to have much fear of me when we are there (a bold one will sometimes come right up and sniff at the bags of feed while I
am in the back of the truck not 4 feet away), it should not be difficult to
rope one, get up to it and toss a bag over its head (to calm it down) then hog tie it and transport it home.
I filled the cattle feeder then hid down at the end with my rope. The
cattle, having seen the roping thing before, stayed well back. They were not
having any of it. After about 20 minutes, my deer showed up-- 3 of them. I
picked out a likely looking one, stepped out from the end of the feeder, and
threw my rope. The deer just stood there and stared at me. I wrapped the
rope around my waist and twisted the end so I would have a good hold.
The deer still just stood and stared at me, but you could tell it was mildly
concerned about the whole rope situation. I took a step towards it, it took
a step away. I put a little tension on the rope .., and then received an
education. The first thing that I learned is that, while a deer may just
stand there looking at you funny while you rope it, they are spurred to
action when you start pulling on that rope.
That deer EXPLODED. The second thing I learned is that pound for pound, a
deer is a LOT stronger than a cow or a colt. A cow or a colt in that weight
range I could fight down with a rope and with some dignity. A deer-- no
Chance. That thing ran and bucked and twisted and pulled. There was no
controlling it and certainly no getting close to it. As it jerked me off my
feet and started dragging me across the ground, it occurred to me that
having a deer on a rope was not nearly as good an idea as I had originally
imagined.. The only upside is that they do not have as much stamina as many
other animals.
A brief 10 minutes later, it was tired and not nearly as quick to jerk me
off my feet and drag me when I managed to get up. It took me a few minutes
to realize this, since I was mostly blinded by the blood flowing out of the
big gash in my head. At that point, I had lost my taste for corn-fed
venison. I just wanted to get that devil creature off the end of that rope.
I figured if I just let it go with the rope hanging around its neck, it
would likely die slow and painfully somewhere. At the time, there was no
love at all between me and that deer. At that moment, I hated the thing, and
I would venture a guess that the feeling was mutual.
Despite the gash in my head and the several large knots where I had cleverly
arrested the deer's momentum by bracing my head against various large rocks
as it dragged me across the ground, I could still think clearly enough to
recognize that there was a small chance that I shared some tiny amount of
responsibility for the situation we were in. I didn't want the deer to have
to suffer a slow death, so I managed to get it lined back up in between my
truck and the feeder - a little trap I had set before hand...kind of like a
squeeze chute. I got it to back in there and I started moving up so I could
get my rope back.
Did you know that deer bite?
They do! I never in a million years would have thought that a deer would
bite somebody, so I was very surprised when I reached up there to grab that
rope and the deer grabbed hold of my wrist. Now, when a deer bites you, it
is not like being bit by a horse where they just bite you and slide off to
then let go. A deer bites you and shakes its head--almost like a pit bull.
They bite HARD and it hurts.
The proper thing to do when a deer bites you is probably to freeze and draw
back slowly. I tried screaming and shaking instead. My method was
ineffective.
It seems like the deer was biting and shaking for several minutes, but it
was likely only several seconds. I, being smarter than a deer (though you
may be questioning that claim by now), tricked it. While I kept it busy
tearing the tendons out of my right arm, I reached up with my left hand and
pulled that rope loose.
That was when I got my final lesson in deer behavior for the day.
Deer will strike at you with their front feet. They rear right up on their
back feet and strike right about head and shoulder level, and their hooves
are surprisingly sharp... I learned a long time ago that, when an animal
-like a horse --strikes at you with their hooves and you can't get away
easily, the best thing to do is try to make a loud noise and make an
aggressive move towards the animal. This will usually cause them to back
down a bit so you can escape.
This was not a horse. This was a deer, so obviously, such trickery would not
work. In the course of a millisecond, I devised a different strategy. I
screamed like a woman and tried to turn and run. The reason I had always
been told NOT to try to turn and run from a horse that paws at you is that
there is a good chance that it will hit you in the back of the head. Deer
may not be so different from horses after all, besides being twice as strong
and 3 times as evil, because the second I turned to run, it hit me right in
the back of the head and knocked me down.
Now, when a deer paws at you and knocks you down, it does not immediately
leave. I suspect it does not recognize that the danger has passed. What they
do instead is paw your back and jump up and down on you while you are laying
there crying like a little girl and covering your head.
I finally managed to crawl under the truck and the deer went away. So now I
know why when people go deer hunting they bring a rifle with a scope......to
sort of even the odds!!
All these events are true so help me God... An Educated Farmer
   / A deer story #2
:laughing::laughing::laughing::laughing:ROTFL
   / A deer story #3
I thought a bought that with the elk that wander through my yard, but after reading your story I thought you might want to come over and try ropin one of them. As an old sailor I knew the story was true as "All these events are true so help me God" was not the first sentence in the story:laughing:
   / A deer story #4
Been a while since I read that one... still funny!:laughing::thumbsup:
   / A deer story #5
I laughed so hard. My favorite part....."I took a step towards it, it took
education".
   / A deer story #8
Never saw this one before. FUNNY! Now I can say I gots me a education too. Enjoyed the read.:thumbsup:
   / A deer story #9
I've read that story and others similar while back ago. Be careful what you attemp to rope. Heres one of my roping stories . :(
Was traveling early in truck in Fla. After Hurricane Andrew totally tore up SE/Fla.Was on road with canal running on north side of me when down the road I spot what I thought at first was a gator.Upon getting closer I see its a Komodo dragon. I thought I could rope him/her take it to right place and make some good $$$$$$$$$ for quick work . Pulled up within 100' of it get my rope from back seat of creww-cab.
I got pretty close to ropeing distance to it when it started hissing,slinging its tonge with v type fork on end.
I got to thinking let me get back in my truck before this thing gets a hold of me instead of me gettin a hold of him/her. Needless to say I let it be and lived to ride another day !
Boone
These pics are not of the one I came across that day.
2000 PETERBILT 357 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2020 John Deere 75G Hydraulic Excavator (A50860)
2020 John Deere...
1972 Ford F600 Grain Truck (A51039)
1972 Ford F600...
2019 Generac MLTS-1 2.4kW Towable Light Tower (A49461)
2019 Generac...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
PTO Pump (A50860)
PTO Pump (A50860)
