955 issue
   / 955 issue #11
I went and filled the tank up with fresh diesel and the problem went away. So I guess it's one of 2 issues:
1: a bad tank of fuel
2: a busted or clogged pickup.
There is another possible cause: The sludge buildup at the bottom of
your fuel tank is getting up to the level of your pickup tube.
All my 955s had sludge in the tanks and they were less than 10y old.
Unfortunately, it is hard to clean out without removing the tank. Newer
JDs have a drain at the bottom of the tank to help with this problem. Even
with the drain, I have had to back-blow thru the valve to break thru the
sludge.
   / 955 issue
sludge.
Do you think there could be that much sludge buildup on a 500 hrs machine?
   / 955 issue #13
Certainly possible. It is probably more a function of age and how the
tractor is stored than the hours.
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A51039)
New Lewis Brothers...
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
