7740 ford
   / 7740 ford #1
dustinkempfly
christchurch
ford John deer messy
Hi guys I've got a 7740 ford the pto kicks out after 20 minutes once it's at about 80 degrees operating temperature. Then it kicks back in slowly and eventually builds up speed again I've buy passed the electrics to rule that out. Put power straight to solinoid on pto still does the same thing. Could it be the solinoid in the pto breaking down or could it be a hydraulic issue. Once it kicks out it kicks out quicker and quicker
   / 7740 ford #2
Reads like a failing solenoid coil. Take accurate resistance readings from the coil feed wire to ground both cold then hot when causing trouble. If the resistance changes significantly, you have the answer.
   / 7740 ford
Would it be worth stripping clutch pack and checking the plates
UNUSED RAYTREE REDM32 32" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
air compressor (A55758)
air compressor...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
2021 Deere 75G (A53317)
2021 Deere 75G...
