7264
   / 7264 #1
smallfarmowner
I've tried the 7254 and the hydro was extremely noisy and it didn't seem to have enough power. I'm new to working a small farm and have about 41 acres. My wife likes to have about 2 - 3 acres mowed around the house and 4 acres are woods. The other approx 34 acres has Multifloral rose growing around. the pastures have had paths cut through them but not a complete cutting in over 5 years. I was thinking about the 7264 with a 60 mmm for the yard, a 48 brush hog for the fields, a 48 rotor tiller, a 48 grating blade, a 610 fel, and 612 backhoe for drains and lite stump removal. I've been quoted around 24 k for a 7254 with all of those toys. What would be a good price for the 7264 or 7284 and where would be a good place near western, Pa to buy it. Would this do the job, or would it be better to buy something like the GT 3235 for the yard work and a larger tractor for the rest? Any help would be appreciated. Thanks
   / 7264 #2
Hi,
I've got a 7264 with a loader and hoe.
The hydro is rather noisy on mine (specifically when cold) but I always wear ear protection when running any equipment.
I really like the machine and have had no problems to date.
I think you could probably handle a 60" hog on the back if you weren't going to wade into super "heavy" stuff.
I've noticed no lack of power for the chores I do , heavy power use being a 4" wood chipper and a 62" rear snow blower.
The power exception would be digging out stumps. I've dug some almost half as big as the tractor(root ball and stump) and couldn't lift them . I had to drag them around.
'Not sure where you live but I'm sure there are some Dlrs. around . Do a dealer search on the Cub site.
For the money , I'd buy another one.
GrayBeard
   / 7264 #3
I've got a 7275 with a Hydro and it is fine. I also have a 72" MMM on it and it will cut thru 8-10 " grass like a breeze. I know where there is a 7300 with FEL and backhoe bracket with 235 hours for $12.5 near Albany N.Y. I have tried this machine and it is super clean. I didn't buy it because it is a standard shift. I will be out of town from tonight thru Memorial Day. If you want the number it will have to wait till then.
   / 7264 #4
I have been shopping around for tractors and like the 7284 (I have been told that they only make that one now). I especially like the 28hp Cat engine. I have heard that you have to service the Cat engine only at Cat - that they won't warranty it anywhere else. Also, the FL and BH don't seem to be very powerful. I was considering moving up to the 7532 TLB - it is much more powerful and seems like the implements match the size of the tractor. I have been looking at the orange BX, and the BH for the 7284 has the same ratings. A little underpowered. I think that the cub tractors are good otherwise. Cub should consider making the 7284 more powerful. Any comments that might help me make the decision would be most appreciated. I have stumps and dirt to move - less interested in mowing - I have a mower already.
   / 7264 #5
I have the 7284 and the motor has alot of power. This is a high torque motor and has more torque at 28hp than the competitors. Thats CAT's trademark High torque. I haven't been able to bog down this motor yet as long as it is operated in the green rpm area 3000 rpm.
   / 7264 #6
Filb,
I don't have any experience with the Cat engine.
Mine is the 26hp Daihatsu. So far it's been fine.
The power has not been an issue but I'm not in a race to do the "chores" either.
I've dug out some 24" white oak stumps with mine with a root ball that I had to drag to the "final" resting place.
As far as the loader , I've picked and moved 650 lb. loads from the back of my truck with no problem.
I don't know your needs on digging but if you've got a lot rocks, huge stumps and not much time ; you may want to look to a bigger machine.
I did look at all the major compacts and chose the Cub.
No regrets.
GrayBeard
   / 7264 #7
Would the 7284 be considered a small-chassis CUT or a sub-CUT?
2015 Hyundai Elantra Sedan (A48082)
2015 Hyundai...
2005 International 8600 Hydro Vac Truck (A50860)
2005 International...
Pallet Fees (A50775)
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
Auger (A50860)
Auger (A50860)
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
