7 pin connector corroded?
   / 7 pin connector corroded? #1
Wayne_H
Davidsonville, Maryland
John Deere 4400, '48 B and 318
OK, on every trailer I've owned (two....) pins five and six (left and right turn signal) connector pins on the trailer ALWAYS get corroded, even though they don't get wet. What the heck?
What are the chances the onboard trailer battery is causing some kind of galvanic action to cause the corrosian? As of now I'm disconnecting the 12V battery when the trailer is not in use, this problem comes up once a year....
Is it just me or does anyone else run into this?
Wayne
   / 7 pin connector corroded? #2
Probably moisture from the roadway. I used to have that problem but I solved it by using a conductive gel from Advanced Auto and put it on the trailer connection so when I plug it in it puts the gel right where it needs to be! It is conductive so I only put a dab on each of the 7 pins. Seems to work great!
   / 7 pin connector corroded? #3
Wayne
I always have the same problem. Less on the 7 ways, more so on 6 ways. Matter of fact I've converted all 10 of my trailers to 7 ways. A little dielectric grease helps, and what position your plug is stored in, I have found, makes a difference of how much rain gets into it.
   / 7 pin connector corroded? #4
Put dielectric grease one then plugs and that will end you problems.
You must clean them up first.
Chris
   / 7 pin connector corroded? #5
This is my experience on a 6 (?) pin trailer. Even new it made poor connection. I figured it was corrosion and used a battery terminal wire brush to shine it up. But later I noticed that the connection would always work if the sag in the connection was lifted with a zip tie or cord to hold the line up. A hole in the bumper where the spare tire jack-rod was a handy to place to tie it "up". Cheers. Mike
Guys: I have tried the dielectric grease route, I really don't see much difference with that.
But, these connectors have seven pins.... why is there corrosion only on the two pins used for the left and right signal (and brake lights)? That is some kind of clue, the metal does not turn green on its own (at least the other five pins don't...)
Just fishing for ideas, I always keep it dry and it does not get moisture in the connector.
regards
Wayne
   / 7 pin connector corroded? #7
What do you use to protect from road spray and humidty in the air?:)
   / 7 pin connector corroded? #8
Have you disconnected the plug and then checked it with a ohms meter to see if there is any stray current present? With everything shut off there should not be any current except on the positive battery supply line.
   / 7 pin connector corroded? #9
i pack my connectors with grease unde rthe caps..
soundguy
   / 7 pin connector corroded? #10
regards
Wayne
My guess would be that those two circuits see the highest current and a much higher number of "on" and "off" cycles. If the contact pressure between the male and female terminals is not adequate, it would be just like switch contacts arcing. What I would do is thoroughly clean the terminals inside and out with steel wool and spread the male terminals a bit with a knife blade. This will increase the contact pressure. Then, coat the terminals with dielectric grease to make it easier to insert the plug with the spread terminals and also keep out moisture. What someone else said earlier about supporting the connector also makes sense, because that would reduce vibration "fretting" the terminals.
Hay Fork (A50860)
Hay Fork (A50860)
2008 Nissan Rogue SUV (A50860)
2008 Nissan Rogue...
2021 Kubota SVL97-2HFC Compact Track Loader (A50657)
2021 Kubota...
2010 Ford Crown Victoria Sedan (A48082)
2010 Ford Crown...
UNUSED Stainless Steel Sink (A50860)
UNUSED Stainless...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
