Bought it like it is. What the title refers to is there is no fel on the tractor.Did it ever work? or did you buy it non-working?
my thoughts too Alex, I'm thinking there is leaking internally but won't know for sure until I find it. Test gauges will be a good start. Currently having terrible shoulder pain and difficult to do much with it, surgery scheduled two weeks from now and after that I'll be full after the problemGet the shop manual, & trace out the schematics. Could be as simple as bad o-rings in the 3pt control valve, or as difficult as rebuilding/replacing the PTO. If you're not leaking fluid externally, you're leaking it internally, the shop manual should give you a diagnostic tree or similar for troubleshooting. If the previous owner replaced hoses, they may have removed the power beyond valve(s) without knowing it, or connected the hoses wrong so you are just pushing fluid to the tank.
