Rotary Cutter 60" or 72" Bush Hog for brush clearing with 40hp
   / 60" or 72" Bush Hog for brush clearing with 40hp #11
Definitely go with the 6' cutter. I know your tractor can handle it with ease. Why would you want to buy a 5' cutter and UNDER USE your tractor? That is my opinion of it.
My tractor can handle a 6 1/2' disk harrow. I am fixing to buy one when I figure out the one I want. I wouldn't go any bigger than that, because it would be too much for it. If I have the horse power and the weight to pull it, then why in the world would I want to go smaller than what it could handle?
You have the tractor. Use it!
Travis R
   / 60" or 72" Bush Hog for brush clearing with 40hp #12
Ed, Everyone seems to be missing the point of the flail mower. Since you will have the flail mower this is what I would do. Beat the crap out of the 4'er and you may be supprised at how long it lasts. My 14 year old 5' house should not be running anymore from what I put it through, but it still is.
If it does wear out. get a HD 5'er to replace it. If your chopping trash, duty not size should matter.
MY .02, mp
   / 60" or 72" Bush Hog for brush clearing with 40hp #13
IslandTractor said:
I appreciate that the 6footer is appropriate for mowing and I will have a 75 inch flail for that task. What if you were only going to use it for backing into thick brush? Would a 5ft version make more sense then or would you still go with the 6?
I don't know exactly how you plan on going about "backing into thick brush", but the first thing that came to my mind from that description was, lift the mower a few inches, back in, and then let the mower down on the brush. That sort of changes things a bit. When I had my farm, I had to mow about 1100 feet of creek bank. It required raising the mower, easing back to "the edge", lowering the mower, then pulling forward. I bought a Woods BB840 to use on my Deere 2440 just for that occasion. 7' mowers are disproportionatly heavy compared to a 6'er. The 2440 is a stout tractor. 60 pto hp, It's ballasted to over 7500#. It handles the 7' Woods mower just fine in ordinary conditions while "going forward" mowing. After a couple cuttings, I went back to my old MD172 Woods mower or a newer Bush Hog 286 I own to cut that creek. (Both 6'ers) That's drastically UNDERKILL on that tractor. If you're going to be doing a lot of manuevering and backing with a raised mower, a smaller than normal mower ISN'T a bad situation.
Also consider you're planning on using the flail mower once conditions permit. That makes a smaller rotary mower less of a long term "liability". If you were clear cutting 100 acres, I'd HAVE to have as big of a mower as money and HP would allow. With 12 acres, we're only talking an extra hour or so per cut to make a once or twice cutting. For rough conditions like clear cutting brush, you might just learn to APPRECIATE that smaller mower.
   / 60" or 72" Bush Hog for brush clearing with 40hp #14
My name is Ed and I'm a tractor junkie.:cool:[/QUOTE]
I thought I was the only mowing and taking land that did not belong to me !
I look at my neighbors lot from my front window and hate it when its is not mowed, so I do myself. The result is more seat time , happy neighbors and a great view. You are going to have great fun with your new tractor. No real cures for a tractor junkie, although more hp does ease the pain.
Good luck,
John
Farmwithjunk said:
..... If you're going to be doing a lot of manuevering and backing with a raised mower, a smaller than normal mower ISN'T a bad situation.
You have summed up my thinking and why I have been considering the 5ft bush hog despite knowing the tractor will easily "pull" a 6 footer. I really need the bush hog just for the initial brush clobbering. What I intended to do was to use a combination of grapple pushing, ripping, lifting and as necessary a bush hog backing into the mess to open it up. Once the land is sufficiently clear that I can drive forwards, I can use the flail (again the flail has hammers so should do fine once I can get the land to resemble a rough pasture). It just seemed logical to me that putting the power into a smaller cutter would be more effective when trying to cut heavy brush. But that thought is not necessarily based on experience.
It appears I have my work cut out for me. Toe to toe combat with Mother Nature. And she is well entrenched. I got some aerial photos today taken in 1939, 1972 and 1992 of the land that I'll be clearing/mowing. In 1939 it was a pristine farm. In 1972 there were junk cars lining the fields and some areas had returned to brush. In 1992, the cars were gone (thank heavens) but the brush was worse. The brush today fully covers one 5 acre field so thickly that you cannot walk at all and cannot even see beyond the first bushes. My original estimate was that the land had not been mowed in 8-10 years but now it appears we are talking 15 years minimum. The only good news is that it is all softwood/brush/vines/briar and it is flat.
Ideally I'd probably use a medium duty cutter like the 285 but the economics don't work for me and this is after all a one time 10+ acre task. I'd hope a light duty Bush Hog would survive that and based on my experience with the SQ480 I think it will. Kossetx's suggestion that I use the 480 I already own is interesting. If I didn't need to jump through hoops to get things delivered to the island I'd surely try that first but I may need to take advantage of the truck/trailer bringing my new equipment over to get everything delivered at once.
Thanks for the advice. I'd be particularly interested in hearing from those who have tackled this type of clearing before.
   / 60" or 72" Bush Hog for brush clearing with 40hp #16
I have a 35hp, 4wheel drive tractor and a 6 foot Landpride Rotary Cutter. If i can run it over, I can cut it up. I've mowed through thousands of small trees with trunks 2 to 3 inches thick and on occasion, a few a little bigger. I just have a shear pin and while backing in and lowering it on some massive blackberries, I broke my first sheer pin. Those berry bushes are much worse then small pines or other saplings.
My biggest problems come from finding stumps. Those will destroy a shredder in an instant!!!
My reason for a 6 foot shredder was to have it cut wider then my tires. I was told this was important, but don't know why. I do know that it's very nice to make a pass through some nightmare of overgrowth and know that the path I just made is wider then my tractor. Most of the time, it's a winding path that I make as I pick and chose my battles. Sometimes you just come to somehting you can't get through, but allot of the time if you go slow, you can work your way through an area. Once you have that first pass through, it's real easy to widen it and open up areas.
Buy the bigger mower. You will have plenty of power with the new tractor and you are just killing time by using a smaller one. There is no advantage to cutting as small an area as possible when you have the power and ability to cut a larger area.
Before you attack the jungle, be sure to spray yourself down with some good bug spray!!! It's not a question of if, but when will you hit a nest of hive of some sort. I cover myself and keep the bottle handy to fight and run away at the same time. So far, I've just been stung a few times, but my dad was just hit real hard by a wasp ground nest and his arms are swollen pretty bad. He didn't spray himself down before he went out.
Good luck,
Eddie
Good luck,
Eddie
Thanks for the implement advice. It looks like the 6ft crowd is out numbering the 5ft votes by 2 or 3 to 1. Your description of how you clear brush is pretty much exactly what I have been doing with my smaller tractor in a smaller area. Sounds like the same techniques will be useful again.
I could have used your bug spray advice last weekend when I ran over a wasp nest. Man they were angry. After a couple of stings, I hopped off the tractor and did a 100yd dash in no time. About 15 seconds later I was shocked to see my neighbor running towards me with a spray can. I asked how he knew what had happened and he simply replied "why else would someone jump off a tractor and run like ****!" :eek: I'll have the bug bomb with me next time.
   / 60" or 72" Bush Hog for brush clearing with 40hp #18
MY .02, mp
That sure is what I would do. Your talking about a one time project before the flail will take over the cutting duties. Why spend over a $1000 for a mower that will sit after the clearing. Besides that you are going to “nibble” away at the field by backing in so what difference does it make if the cutter is as wide as the tractor? If durability is the issue invest a $100 bucks for a slip clutch.
I don’t think the time to clear the land is going to be significantly better with a larger mower and who gets a new tractor that is worried about how long they spend on it at first?
What are you buying?
MarkV
OK guys, I've made a decision. Thanks for the advice, all of which seems quite reasonable if somewhat contradictory.
I'm going to hold off buying a new Bush Hog and will first try to do my clearing work with the new flail mower and grapple. If that is not effective I'll use my SQ480 to see if that speeds things up and will judge then if I should get a new bigger rotary cutter. It will be a hassle if I do need at a later date to get a new cutter on the island but if I don't really need a cutter it will avoid the cost of the new implement.
My strategy will be to mount the flail and use it in combination with a grapple/FEL to rip through the bushes. I was shy of doing that based on my experience with the CK20/grapple which worked well but was too slow for the amount I need to do. The Kioti KL401 loader has 2700lbs of lift capacity at PP and 3700lbs of breakout force so I can probably just lift the bushes out of the ground with a single yank rather than working them loose like I did before. That will be the plan anyway. Once I get the bushes sideways on the ground I don't think the flail will have any trouble. So, I may end up going through this brush forwards rather than backwards after all.
I'll report and post some photos on my experience after the weekend.
MarkV said:
That sure is what I would do. Your talking about a one time project before the flail will take over the cutting duties. ....
MarkV
Thanks especially to you and Kossetx and FWJ for reemphasizing the role of the flail mower as I thought through this issue. That was the original plan but I kinda got worried last weekend when I went to inspect the property again and saw that the brush was about 10 feet high and some quite woody.
In answer to your question about what tractor I am buying, I am trading in my trusty CK20 TLB for a Kioti DK40se HST with Woods BH90x. Simple switch really, just called up Barry Bonds who sent me a few syringes of TGH (tractor growth hormone) and after that plus a modest cash injection I expect the transformation to be complete by Thursday evening. Double the horsepower, weight and lift capacity. I'm keeping my Millonzi grapple (the DK has a universal quick attach) and also adding an almost new WR Long 4n1 that I stole :cool: off ebay ($511 delivered including diverter valve kit complete). The Caroni TM1900 75" flail will do the mowing duty. I'll hang on to the SQ480 for a while then sell it or upgrade if necessary to the SQ720.
Sellick S80 (A53317)
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55315)
2025 Mahindra 6075...
TOP WIND SCOOP W/ PARTS & BRACKETS (A57192)
TOP WIND SCOOP W/...
2022 John Deere 6120M (A53317)
2022 John Deere...
UNUSED FUTURE FT-ZP210 20' X 30' ALLSTEEL GARAGE (A57193)
UNUSED FUTURE...
2015 John Deere HX15 (A53317)
2015 John Deere...
