davebb
I put a test light on the terminal with the key on and it has power. Sometimes it starts and runs great other times it just cranks. It'll run on starting fluid but not stay running. I took the solenoid out and is pulls the valve in every time I put 12 volts to the thing. I put it back in and it runs but then started doing the same no start sometimes. Funny symptom is when I put a test light on the terminal and crank, it starts but remove the light and try again no start. Put the light back and it starts. It did this about 6 times in a row then it wouldn't start even with the test light on it.
I guess for a test I'll have to remove the spring loaded valve inside and it's spring and reassemble the solenoid without those and see if it starts every time.
Anyone ever run into this problem?
