Backhoe 555A Losing coolant
   / 555A Losing coolant #1
housemasters
My 555A Ford backhoe diesel loses about a gallon of coolant every 4-5 hours, but no leaks are evident. I notice what seems like a lot of moisture coming from the tube that comes out of the valve cover. May be some water in the oil also. Has anyone had this problem or know what it is?
   / 555A Losing coolant #2
Electrolysis? If it is not a head gasket. I have seen cylinder liners eaten through until there are pin holes in the cylinder wall. I have no idea why it seems to happen predominately in Ford equipment. I have been given a thorough explanation, years ago, and there is no way I could recite it now.
I would drain the engine oil, leave the drain plug out. Top-off the coolant and pressurize the cooling system with a pressure tester. If coolant is leaking into the crankcase you will see it come out of the oil drain hole. The only way to confirm if it is a head gasket or pin hole in a cylinder liner is to remove the head and inspect the head gasket. If there are no apparent tracks where coolant was passing into the crankcase, you'll need to get the head checked for cracks. To check if it is a cylinder liner you will have to remove piston and rod assemblies. The pin holes typically happen below the top of the piston when it is at bottom dead center. You could skip pulling the head and pistons by pulling the pan and pressurizing the system and looking to see where the coolant was coming from, rotating the crank so the bottom of each cylinder is exposed. Either way is a bit of work.
Brian
   / 555A Losing coolant #3
the electrolysis and cavitation happens on the wet liner engines because the owners are too cheap to put in the 4-6$ sca/dca addative when they change their coolant..
soundguy
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2014 New Holland C238 Tracked Skid Steer (A50860)
2014 New Holland...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2012 Ford F-250 XL 4WD Flatbed Pickup Truck (A50860)
2012 Ford F-250 XL...
Floor Lamp (A48083)
Floor Lamp (A48083)
