Backhoe 510 D won't move
   / 510 D won't move
Electrical isn't my strong suit so without a book I'm in over my head . I've read where it's possible the park brake switch could be the culprit , At least for the park brake / FNR fuse blowing. Machine is pretty clean and wiring seems to be protected well with looms and appears to be in good shape what I can see of it anyway.
   / 510 D won't move
Thanks again for the tips , Is there a way to bypass the whole electrical system and make sure park brake is backed off and run jumper wires to operate FNR just to try to get moved ? If possible that would be the deciding factor if it's electrical or mechanical . I can't hear or feel any click of the solenoids working on the reverser .
   / 510 D won't move #13
You should have a "cage" bolt that will manually release the brake.
Follow the PB line going to the housing in the axle and you seen a bolt with a jam nut on it. Screw that bolt in.
The clutch disconnect should have a 2 wire weather pack connector at the base of the loader lever. Un plug it and you can then; 1- check for continuity on the switch(should be open when released)(closed when depressed) 2- power to the switch.
The light on the dash is turn on or off by park brake pressure. It uses a normally closed pressure switch that opens around 150+/- psi, in turn turning the light off.
2011 Kubota ZG222 (A56469)
2011 Kubota ZG222...
2007 Ford F-150 Ext. Cab Pickup Truck (A55852)
2007 Ford F-150...
UNUSED X-STAR 101" X 20' LOADING RAMP (A57192)
UNUSED X-STAR 101"...
UNUSED 1RANCH 1RGPM GROUND PROTECTION MATS (A57193)
UNUSED 1RANCH...
2000 FREIGHTLINER FL60 S/A FLATBED TRUCK (A57192)
2000 FREIGHTLINER...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
