5085E Pwr Reverser after a few mins of running won稚 Tk gear unless you use clutc
   / 5085E Pwr Reverser after a few mins of running won稚 Tk gear unless you use clutc #1
Brown Dog
Veteran Member
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
Tractor will take gear w/o using Clutch after it’s first cranked but after a few mins of use, you have to clutch every time or you get the dreaded alarm & neutral light flashing :thumbdown:
I’ve bypassed the seat switch : didn’t help
My 5093E & 5101E both take gear every time with no clutch.
This is what I’m used to & & I’m the only operator.
Anybody know of an adjustment or mod I can do to the clutch switch or anything else ?
   / 5085E Pwr Reverser after a few mins of running won稚 Tk gear unless you use clutc #2
Re: 5085E Pwr Reverser after a few mins of running won稚 Tk gear unless you use clu
It sounds like you have a problem in seat switch circuit. The computer can tell if seat switch is bypassed. If it is bypassed for more than a day, it will set a code and not allow the shift the same as if you are not in the seat. Try disconnecting the bypass and then restart the tractor before reconnecting it again to see if it works properly for a day. If it does that proves the wiring to controller is good you probably need a new seat switch. It it still won't work, you may have a bad wire or the controller may be going bad. ANother reason for not bypassing the seat switch is it will eventually drain the battery if not run often enough.
I’ll try that.
What I’m calling bypassing the seat switch :
I actually Unplugged the seat switch & wired the two wires together on tractors wiring harness.
I separated the two seat switch wires from where I had them wired together & tractor would not take gear with OR w/o using clutch.
I wired harness back up to the seat switch like it originally was & it takes gear w/o clutch so far .....
   / 5085E Pwr Reverser after a few mins of running won稚 Tk gear unless you use clutc #5
My bulldozer was doing that, and it ended up being the hydraulic filter for the reverser. I am not sure if your tractor has a separate filter for the reverser, but my bulldozer was a John Deere so it might have the same engineering.
TEST YOUR BID BUTTON! (A51244)
TEST YOUR BID...
International 806 2wd Tractor (A52128)
International 806...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
2015 F-550 Bucket Truck. (A52128)
2015 F-550 Bucket...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
