5075e with hay forks
   / 5075e with hay forks #1
North Texas
1953 Ford Golden Jubliee
This photo is for fishpharmer...this is the best pic I have of my hay fork/spear. This implement can be used as both and I would suggest getting this over a separate fork and spear.
   / 5075e with hay forks #2
Thanks for the pic TripleMoutdoors.
The forks look like they would work well for general hay moving. I am leaning toward pallet forks to move lumber and a seperate bale spear. The reason I think I need a hay spear is for loading hay on a gooseneck trailer, the pallet type forks on the bottom of the bale may dig in the wood deck. They might not if I am very careful, I am loading 4'x5' bales. Also, If the hay is stacked, will the forks damage the net wrap?
What do you think?
Thanks
When I load a gooseneck or move the bales I spear in the top third of the bale. When I'm loading on top (double stack) I spear the bale in the bottom third of the bale. My spears are movable just like forks. I can pick up a pallet or a load of lumber if blocked up.
What do you think?
Thanks
You spear the bale...so you are not near the wrap.
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
377780 (A48837)
377780 (A48837)
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
