5075e with hay forks
   / 5075e with hay forks #1
North Texas
1953 Ford Golden Jubliee
This photo is for fishpharmer...this is the best pic I have of my hay fork/spear. This implement can be used as both and I would suggest getting this over a separate fork and spear.
   / 5075e with hay forks #2
Thanks for the pic TripleMoutdoors.
The forks look like they would work well for general hay moving. I am leaning toward pallet forks to move lumber and a seperate bale spear. The reason I think I need a hay spear is for loading hay on a gooseneck trailer, the pallet type forks on the bottom of the bale may dig in the wood deck. They might not if I am very careful, I am loading 4'x5' bales. Also, If the hay is stacked, will the forks damage the net wrap?
What do you think?
When I load a gooseneck or move the bales I spear in the top third of the bale. When I'm loading on top (double stack) I spear the bale in the bottom third of the bale. My spears are movable just like forks. I can pick up a pallet or a load of lumber if blocked up.
What do you think?
You spear the bale...so you are not near the wrap.
2025 K4525 UNUSED Double Garage Steel Barn (A50860)
2025 K4525 UNUSED...
1995 Ford F-700 Flatbed Truck (A50860)
1995 Ford F-700...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
Heavy Duty Forklift Plate and Forks (A50860)
Heavy Duty...
2015 Hooper T/A Trailer w/ Mounted Foaming System (A50860)
2015 Hooper T/A...
Lot of Misc Stihl Weedeaters and Trimmers (A48083)
Lot of Misc Stihl...
