5055E engine RPM increase
   / 5055E engine RPM increase #1
fieldman12
OHIO
2001 New Holland TN70,2003 John Deere 250 Series II skidsteer,1987 John Deere 2155,2013 John Deere 5055E MFWD,2007 Duramax 4x4 truck, 1973 MF 165,Artic Cat 550 Cougar sled
Has anyone noticed on there tractor the engine Rpm's increase maybe a couple hundred RPM's and stay there on its own. I noticed if I start my tractor every once and a great while, let it idle for a couple minutes, and then maybe increase the RPMS to 1200 that when I put it in gear and start to take off in low gear the RPM's increase a little more on its own. Like I said it only happens every once in a great while and just does it the one time when I first started it after a few minutes. From then on it does not do it and runs as it should. I thought maybe it was the linkage moving that goes to the fuel pump but it does not appear to be that. I am going to check hoses and see if any are loose but I don't see any fuel drips. Like I said it does not do this after a few minutes every time I start it just some times
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
