50 hour service - B2920
   / 50 hour service - B2920 #1
donn12
Platinum Member
Great Falls Virginia
B2920 TLB turfs and loaded ags
I know from another post it holds a lot more than 3.7 quarts of oil. Any other tips? oil and filter change, hydro filter change and adjust clutch pedal? I did not see anything about a magnet for shavings like my BX24 had. all info will be appreciated!
   / 50 hour service - B2920 #2
I just changed out the oil on my B2620 and it was under 4 qts. The 2920 was listed as slightly more capacity than mine.
   / 50 hour service - B2920 #3
I had the lift the front of my B3030 when changing the oil because there was cross member right below the drain plugs to avoid having the oil hit the ground over a wide area.
   / 50 hour service - B2920 #4
Someone posted where they put a spigot on and hose to get around having to do this; don't remember the thread though.
I read in another thread that there is a trans filter and a hydro filter? I thought they were the same thing? I only biught a hydro filter...am I screwed?
   / 50 hour service - B2920 #6
The loader brace is not hard to remove at all in order to drain the engine oil. There are 2 17MM head bolts on each side and the brace comes right out allowing easy and clean removal of the engine drain plug.
   / 50 hour service - B2920 #7
Nah, if you're worried about the oil that was left in it? Too small amount to be concerned. But, go ahead and change it now.
Got under the tractor today and it has a hydro filter which I bought and a trans filter which I didn't. The manual calls for the trans filter only at the 50hr mark but I will probably replace the SUDT as well as the hydro filter. As far as the oil change I left the loader brace in place and it was fine - the oil drained in front of it. Unlike another member mine took 4.5 quarts of oil. I am going to replace the air filter as well because it still looks like crap even after blowing it out with compressed air.
   / 50 hour service - B2920 #9
I have a B7800 and I think it has the same size engine as the B2920. Manual says 4.1 quarts but I always put in 4.5 quarts to make the dipstick happy. I change both hydro filters when I change the hydro oil. I replace the air filter every spring even though the hours in the manual say not to.
   / 50 hour service - B2920 #10
Donn12 - congradulations on the 50 hour change!!!! :thumbsup: Fun eh? :laughing: ....as you found out there are indeed 2 filters (well 3 if you count the engine oil one) :confused2: - I was told all ya got to do is spin on the hydro and tranny filter real fast so you dont loose much oil (yea right) - it was comical trying to catch threads and watching the oil gush out :mad:- so what I'm say'in is your going to want to replace the hydro oil (nothing wrong with that). Did ya see the two oil fills on the engine - maybe Kubota will show both on the next B series operator manual re-print - I'm at 80 hours now and just looking forward to doing my next service. Oh what fun!
Giyi 72" Box Broom Sweeper (A57149)
Giyi 72" Box Broom...
ALLMETAL MOBILE PRESSURE WASHER (A58216)
ALLMETAL MOBILE...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
