4tnv98 questions about internals and head damage
   / 4tnv98 questions about internals and head damage #21
I cannot image a round disk would make me happy once the straight edge came out. I have a guy on marketplace with a good head, waiting on a shipping quote for that. If it does not pan out soon I will buy a reconditioned one online, they sell for 6-700. If you went with a stone what grit would you recommend on the block? I can see that stone has 1000 and 6000 so I was curious. When using a stone what should I wet the surface with? Was thinking wd40 but what the hell do I know, lol . I already drained the coolant because it likely has oil in it or combustion gas. If I plan to flush it with water, drain, then fill with new coolant should I still plug the coolant jacket holes? Thanks for all the help!
For a good flat surface the best bang for the buck is a granite surface plate. Less than 50 bucks for your purposes. See this link: https://www.jbtools.com/hhip-12-x-9...VaYepTrfTKGTnhEs30KmAqGR_PPeFaOhoCdR4QAvD_BwE
The surface plate will check your pushrods. Then a piece of wet or dry sandpaper can be used to flatten the block if need be. The sandpaper can be glued to the surface plate with spray contact adhesive. Oftentimes just wetting the sandpaper with kerosene is good enough to keep it stuck to the surface plate. So you could wet the sandpaper with diesel, stick it to the surface plate, then invert the plate over the block and use the sandpaper to flatten the block. You don't need to go any finer than 600 grit. Start with 240, then 320, then maybe 400. And then 600 if you really want to. You can sand the head too on the surface plate. If you decide to stone the block then 1000 grit is still way too fine. Use diesel, kerosene, or tiki lamp oil for the stoning lubricant. Float plate glass is plenty flat too, theoretically with the radius of the earth, but you need thick glass and larger thick pieces start to get expensive. Glass is not as stiff as granite so it will deflect before granite. A 2 inch thick piece of granite is way stiffer than a more expensive 5/8 thick piece of plate glass with the same 9 x 12 dimensions.
Eric
   / 4tnv98 questions about internals and head damage #22
I'd go around 200-400 in that range, I should have looked for a better pic, that was just to give you the idea of the size, sorry. As for lube WD-40 works good, thin enough to flush the bits out of the way, think enough so it stays in place....somewhat LOL.
It wouldn't hurt but I'd still be flushing, be more concerned about the oil passages to keep the crap out of them as well as the cylinders.
I think Dodge man was referring to getting the head done at a local shop, not the complete engine. If the head looked to be in better shape, that would be my first thought to, probably a bit cheaper but I think that is beyond. Wouldn't hurt to take it to a shop and see if they can do it if it is salvageable and how much $ .
Eric
Thank you for this information. Is there a specific type of wet dry paper that needs to be used or is standard stuff just fine? I like this granite idea and will be getting one.
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
Deere 310L (A53317)
Deere 310L (A53317)
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2022 Kubota RTV-XG850 Utility Cart (A56857)
2022 Kubota...
2018 Bell B30E 30 Ton Articulated Dump Truck (A55973)
2018 Bell B30E 30...
